Author Topic: Vag Tacho  (Read 18059 times)
Offline G60GTI16V
  • GTI Mk1, 2, 3, 4 now VRS Hell Yea!
Vag Tacho
« on: 31 March 2010, 17:14 »
I want to get this working so i can make adjustments but cant seem to find anywhere to download a new version like 2.5. i got a v1.1 but it does not seem to work. any ideas?
also will it work with my standard 10 quid ebay cable which i can run vag com on?
Offline Jay
  • balding fat cvnt
Re: Vag Tacho
« Reply #1 on: 31 March 2010, 17:31 »
I've read of some VAG COM ebay cables working with VAG Tacho, but tbh it probably won't work. I've seen VAG Tacho cables going for £25 on ebay if that helps.
Offline G60GTI16V
Re: Vag Tacho
« Reply #2 on: 31 March 2010, 18:08 »
what is the difference? i bet it has exact same pin configuration etc...
where can i get decent vag tacho software on the dwnld :evil: ?
Offline Jay
  • balding fat cvnt
Re: Vag Tacho
« Reply #3 on: 31 March 2010, 19:30 »
The pin configuration is the same (16 pin(?) ODBII connector ) but it's the electronics in the connector end of the cable that is different to the vag tacho cable in most cases.
Offline richw911
Re: Vag Tacho
« Reply #4 on: 31 March 2010, 20:55 »
A vag com lead wont work with vag tacho software  :smiley:
Offline topher
  • Administrator
  • fully functioning
Re: Vag Tacho
« Reply #5 on: 31 March 2010, 21:14 »
my tacho lead has some sort of circuitry in it. im not sure if the ebay ripoff ones are the same or just use a generic obd usb lead and deal with the the electronics with some software hacks. if the latter then you can get drivers to use your vagcom lead as a generic obd lead... never tried it myself though.
Offline Jay
  • balding fat cvnt
Re: Vag Tacho
« Reply #6 on: 31 March 2010, 22:58 »
I'll give that a crack toph, not sure if I'll plug it into mine or someone elses when I test it :evil: Can't have my car being bricked now can I?  :rolleyes:
Re: Vag Tacho
« Reply #7 on: 01 April 2010, 12:09 »
if its a dodgy ebay cable be carefull! the later versions of vag-tacho can wipe the firmware on the cables if it sees that its a dodgy one
Offline G60GTI16V
Re: Vag Tacho
« Reply #8 on: 02 April 2010, 17:04 »
there is a circuit board in my ebay usb cable, only 4 of the pins on the odb side are connected to the pcb inside. where can i get the vag tacho software from i only got v1.1 and it keeps sayin k-line not found and wont connect to anything  :angry:
Offline topher
  • Administrator
  • fully functioning
Re: Vag Tacho
« Reply #9 on: 02 April 2010, 19:17 »
AGU? possibly because there is no live on the kline pin for that ecu. Could always put a wire from the battery to pin 43 on the ecu to test. See if you can try it on an aum first though, the cable itself might be screwed.
