Author Topic: Vag Tacho  (Read 18060 times)
Offline topher
  • Administrator
  • fully functioning
Re: Vag Tacho
« Reply #20 on: 26 October 2011, 23:55 »
do the "connect any tacho" every time.. it's not scanning the same 2 channels every time.
you're either doing it wrong, have an unsupported cluster or the cable/cluster is faulty
Offline Dave_IOW
Re: Vag Tacho
« Reply #21 on: 27 October 2011, 00:04 »
Right bud, i clicked on Connect any tacho, and it scanned 2 sort of 'channels', thats the best way i can describe it, over and over, possibly 9600 and 1400 or something like that.
When i got bored of watching that, and tried to connect to VDO new just to see it not work, i went back on the 'connect any tacho' and it seemed to scan the same 2 again.
Its an IMMO 2 bora sport cluster with part numbers that match up to a part number on a thread by old_no7.
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline topher
  • Administrator
  • fully functioning
Re: Vag Tacho
« Reply #22 on: 27 October 2011, 00:07 »
plug the new clocks in, connect vcds and open the instruments module, it'll tell you the type of cluster in the right hand field. check for fault codes while you're in there too.
Offline Dave_IOW
Re: Vag Tacho
« Reply #23 on: 27 October 2011, 00:22 »
Will do tomorrow, if i get really stuck, ill take a video of whats happening, im not that great at explaining  :sad:
