Author Topic: madmanluke's supercharged mk2 VR  (Read 379257 times)
Offline madmanluke
Re: madmanluke's mk2 VR
« Reply #240 on: 12 April 2011, 15:55 »
Agreed its not really what Im after but great to see just for ideas. Maybe I can just put some sort of pollen filter in the housing? That should catch any stray water dripping down. Would need to be replaced fairly often....
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #241 on: 12 April 2011, 15:58 »
Honestly mate your best option will be a removeable raised cover.. any type of filter is not likely to be waterproof and will perish quickly with english weather
Offline madmanluke
« Reply #242 on: 12 April 2011, 16:30 »
Agreed it wont last long. How would you suggest mounting it then? remember I have no scuttle at all. I dont really want to be drilling mounting holes etc for it so would need to be something that can support its self.
Thinking about it, will it ever see water any way? The bonnet has no vents above that area from what I remember, so I might be able to get away with one completley? Maybe just silocone seal the hosuing to the firewall to stop any thing seeping down there...
Offline popleyruss
« Reply #243 on: 12 April 2011, 16:35 »
Very true tech
Just plain dubbin
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #244 on: 12 April 2011, 16:50 »
maybe like a domed piece of steel with a ring underneath that can be pressure fit on top maybe ??
Offline madmanluke
« Reply #245 on: 12 April 2011, 21:05 »
Thats a good idea. Id need to be able to either have that made up or be able to fold a sheet piece of mettle my self.
got my 2 pole rad fan switch through today. tested and the fans kick in perfectly.  Pretty happy with that. Such a simple solution to that arse ache of a rad fan control unit. Getting closer to getting the engine out again.
Offline lemski
  • 16v
« Reply #246 on: 12 April 2011, 21:14 »
You would make it your self. Just have to have a piece of sheet metel with to ends like a box, bend the two ends 90 degree, then bend them again 90 degree opposite way to mouint to scuttle. Then spray what colour desired. Job done. U could evan mod the old air vent by just cutting wing side out and plating over the meshed bit.
Good the fan switch works
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #247 on: 12 April 2011, 21:17 »
Above seems a good idea.. or you could easily give a fabricators some rough dimensions and they could fab something up..
Wicked news on the Fan switch are they easy to wire in ??
Offline madmanluke
« Reply #248 on: 12 April 2011, 22:06 »
Il see how things progress as to what way I go with this. Need to make sure I get everything working before i worry about my heater blower haha
Offline lemski
  • 16v
« Reply #249 on: 12 April 2011, 22:09 »
Good point that mate. What exactly did u remove from your engine loom?
