Author Topic: madmanluke's supercharged mk2 VR  (Read 379263 times)
Offline madmanluke
Re: madmanluke's mk2 VR
« Reply #220 on: 10 April 2011, 21:12 »
Got started on the rad fan loom today. Slim lines mounted up fine and run fine. Need to get hold of a 2 pole rad fan switch for the radiator before I can test to make sure they kick in fine. Got to do a bit more fab work to get the radiator to mount to the front cross member and the front slam panel also.
Plugged in the interier looms again, clocks work, dipped and full beam, hazards, side lights, wipers and fogs all work fine.  Just need to test the brake pedel switch once i find that and the washer bottle.
Good days work today. Just waiting on that rad fan switch, them its all coming back out again and then the cosmetics really kick in.
« Last Edit: 10 April 2011, 21:26 by madmanluke »
Offline cняis
« Reply #221 on: 10 April 2011, 21:14 »
how come you went for slim-line fans on the front of the rad? have you got clearance issues behind the rad?
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #222 on: 10 April 2011, 21:15 »
Thats looking really sweet mate.. was just looking in your project thread a second ago..
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #223 on: 10 April 2011, 21:17 »
Also mate just a quick question by why remove the scuttle panel ??
Offline madmanluke
« Reply #224 on: 10 April 2011, 21:21 »
The slim lines went in front as I am tidying the bay. Its just so they are not on show, out of sight but still doing their job. The rad wont breath as well whilst on the move, but It should be fine.
As for the scuttle. It was knackered from when my old PB block went in and out about 5 times. The inlet manifold used to smash into it and it was bent and twisted. I figured Id just loose it and open the bay up. Kind of prefer it with out the scuttle pannel. It comes with its challenges though. No 1 is the spot welds. thingy of a job. haha , second is that rain water will just drop straight down the firewall so can get in through the rubbers that I am leaving there. So they will need to be sealed up. Next is water getting into the interior air intake. Haven't figures out how Im going to solve that yet, but Im not plating it over and removing it as I want fresh air in the cabin.
« Last Edit: 10 April 2011, 21:25 by madmanluke »
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #225 on: 10 April 2011, 21:23 »
wheres your ECU mounted wont that just get soaked ??
Offline madmanluke
« Reply #226 on: 10 April 2011, 21:24 »
Inside mate. its been inside since the original build. ECU's are water proof regardless. :)
Offline madmanluke
« Reply #227 on: 10 April 2011, 21:26 »
Double Image post fail. Heres what it should have shown
« Reply #228 on: 10 April 2011, 21:32 »
Excellent progress. :afro:
Offline popleyruss
« Reply #229 on: 10 April 2011, 23:25 »
Luke I've seen a cover for the fan made Dom a piper x filter with an extra bit of plastic before to cover that inlet I'll try and get a picture tomoro and I'll stick it on your Facebook you may be able to do the same looks pretty good aswell to be honest
Just plain dubbin
