Author Topic: Fitting Boost guage  (Read 3624 times)
Offline Purely VAG
Fitting Boost guage
« on: 18 March 2010, 16:56 »
Got my boost guage to fit and it came in 2 parts, the LED guage and the vacuum inlet seperate, both have wires coming out, i don't understand as thought theyre one unit i wire in and put vac from FPR job done
Anyone know how they supposed to go?
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Fitting Boost guage
« Reply #1 on: 18 March 2010, 17:22 »
pics?
From your description I would have said the vac part is a sensor which sends the figures top the readout?
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #2 on: 18 March 2010, 17:58 »
sounds like you have an electronic gauge with Gauge and sender. if so vac pipe runs from fpr vac line to sender unit and the wires from sender unit to gauge.
Offline Purely VAG
« Reply #3 on: 18 March 2010, 18:02 »
Heres a pic lads,
Do i wire just cross the sender wires with the guage(colour to colour) then wire up to ignition live/earth
Offline DarkGti
« Reply #4 on: 18 March 2010, 18:45 »
i'd just wire them together jord then wire them up as normal!
dub268
« Reply #5 on: 18 March 2010, 18:53 »
Looks like mine I've just fitted, black will be earth, red live and green is sender, I joined to each matching colour and then add extra length wire to reach fuse box and vac line connects to sender job done  :grin:
Offline Purely VAG
« Reply #6 on: 18 March 2010, 22:07 »
So basically if i understand right,
Vac sender/guage cross red/red, black/black, green/green then run red to ignition 12v and black to earth. Job done?
Offline tg1
« Reply #7 on: 18 March 2010, 22:47 »
don't you need a no buzz t piece of something?
might be chatting rubbish bit mushed  :smug:
Offline Purely VAG
« Reply #8 on: 18 March 2010, 23:47 »
Don't "need" one but thanks for reminding me as that is something i want to put inline.
Offline Waffs1984
  • Spacers are for chumps...
« Reply #9 on: 19 March 2010, 08:51 »
What make is that gauge if you don't mind me asking Jord?
Mk4 GTi-T AUM l R-Tech Stage 1 l AP Coilovers l Forge 007p l New Style RS4's 18" l Toyo Proxies 4 l Hofele Bumper Grills l Silver Interior Trim l N249 Bypass l Front & Rear Powerflex bushes l Forge TIP l CAI l GolfGTi.co.uk Stickers l Catch Can Fitted & PCV System Deleted l Redstuff Rear Pads l More to come...
