Author Topic: Fitting Boost guage  (Read 4054 times)
dub268
Re: Fitting Boost guage
« Reply #10 on: 19 March 2010, 10:19 »
So basically if i understand right,
Vac sender/guage cross red/red, black/black, green/green then run red to ignition 12v and black to earth. Job done?
that's they way i done it on mine and it works  :grin: ive had no need for buzz t piece either  :grin:
Offline Purely VAG
« Reply #11 on: 19 March 2010, 21:20 »
Fitted it, ill upload pics to my build thread soon.
On idle its at -10 is that right ?
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
Offline topher
  • Administrator
  • fully functioning
« Reply #12 on: 19 March 2010, 21:22 »
either that's what the gauge bottoms out at or you have a vac leak - i'd be inclined to go with the first option as that's exactly how our innovate boost logger behaves too - probably the same map sensors! Still it doesn't hurt to have a quick look for telltale grime around leaky vac pipes.
Offline Purely VAG
« Reply #13 on: 19 March 2010, 21:24 »
I installed the Vac line all way from FPR to guage pal. 1 piece line, tight at both ends
Offline topher
  • Administrator
  • fully functioning
« Reply #14 on: 19 March 2010, 21:28 »
Engine vac leak dude. But to be missing 10hg it'd probably be some huuuuuge hole. Like i said most likely its just how the sensor works. I suppose one way to test is borrow an analogue boost gauge from someone for a few minutes and plug it into your vac line, see what it reads.
Offline Purely VAG
« Reply #15 on: 19 March 2010, 21:31 »
Ahh ok mate. Well im going to take it for a run on bypass tomorrow to see what it boosts upto. Guage reads 0 with engine off if that makes a difference.
Offline MaXXeH
  • Golf MK5 GTI
« Reply #16 on: 19 March 2010, 22:14 »
mine is -24 bloody thing everyone else is like 18-20  dunno if it is a sign of a problem
Offline Purely VAG
« Reply #17 on: 20 March 2010, 09:22 »
haha not just me then.
Offline Purely VAG
« Reply #18 on: 21 March 2010, 10:50 »
Took it for a run,boosts 25psi peak, so the guage works !
Offline D4VEY01
  • 1999 GTI 1.8T AGU BLACK
« Reply #19 on: 24 March 2010, 21:58 »
Which pipe is the FPR :embarassed:
1999 : GTI : 1.8T : AGU : SPEC 1 R-TECH REMAP : BOSCH SUPER 4 : FORGE TIP : SILICONE TURBO HOSE KIT : 18" RS4 ALLOYS : -30MM ADJ SPAX SHOCKS/SPRINGS : FORGE 007P D/V (YELLOW) : MILLTEK CAT BACK RES 4MOTION : POWERFLEX DOG BONE BUSHES : PIPERCROSS FILTER : FORGE ACTUATOR (YELLOW) :
