Author Topic: Engine mounts  (Read 5002 times)
Offline Tucker
Engine mounts
« on: 09 November 2004, 22:42 »
Right peolple,
I have had enough of my zorst rubbers breaking due to worn mounts, front mount is a pi$$ of pi$$ to do but the rear??
Picked the front and rear up today from GSF and going to do em tomorrow.
Just need to know what the rear one is like to do and the best way of changing the bugger
http://i10.photobucket.com/albums/a109/sydney04/mk116vsmallpic.jpg
Sig too large, see forum guidelines - Admin.
Offline Gambit
Re: Engine mounts
« Reply #1 on: 10 November 2004, 09:50 »
rear one is a fiddly job. lot easier if you have access to a set of proper ramps
id quite happily leave the car into a garage and let them change it - should only cost ?25 tops to fit
did u go for the later 16v hydro mount on the rear?
the combo you want is
16v solid rubber front
solid rubber gearbox
16v rear hydo mount
Offline Tucker
Re: Engine mounts
« Reply #2 on: 10 November 2004, 10:56 »
I dont mind getting dirty, got me a set of car ramps that will get her up.
Monies a bit tight at the mo so will be doing it myself ;)
I went for the standard ones as monies tight and its an early 84 (k jet i think)
How much of a fiddly job is the rear?
Tucker
Offline benjam_in
Re: Engine mounts
« Reply #3 on: 10 November 2004, 11:28 »
very fiddley! took me fookin ages to do mine! luck i did in the summer!
Golf Mk2 Gti 1988
Offline Tucker
Re: Engine mounts
« Reply #4 on: 10 November 2004, 11:33 »
So what needs to be done to get the bugger off?
Offline benjam_in
Re: Engine mounts
« Reply #5 on: 10 November 2004, 11:50 »
its quite a phsyical job as the bolts are fcuking tight an not the easiest to get to! get the car in the air in have a look at its postion its hard to get at! i thought it would be easier to take off the whole mounting braket then take the mount out of that but i turns out it wasnt! lol
Golf Mk2 Gti 1988
Offline Tucker
Re: Engine mounts
« Reply #6 on: 10 November 2004, 12:42 »
Offline dubslug
Re: Engine mounts
« Reply #7 on: 10 November 2004, 15:36 »
u doing gear box side??
1992 pearl grey 8v
Offline Tucker
Re: Engine mounts
« Reply #8 on: 10 November 2004, 15:38 »
Not at the mo, just doing the two and seeing how that goes (front and rear)
Offline dubslug
Re: Engine mounts
« Reply #9 on: 10 November 2004, 15:46 »
ah cant help then sorry just done gearbox side sunday
1992 pearl grey 8v
