Author Topic: Engine mounts  (Read 4999 times)
Offline ...joe
Re: Engine mounts
« Reply #10 on: 10 November 2004, 15:59 »
shouldn't be too bad but like benjam_in said the bolt are pretty tight as they tend to get all kinds of sh!t thrown at them. also i managed to snap one of the bolts going through the alloy bracket thing, which didn't help matters at all!
get out there witha load of WD40 and let it all soak in before you have a crack at it. should make things easier!
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Veedubgt18v
Re: Engine mounts
« Reply #11 on: 10 November 2004, 18:01 »
i just did all mine in a garage cos i couldnt be arsed, its cold, cost me 153 total, solid front solid gear hydro rear, loads smoother now and easier to change gear and it doesnt pop out of fourth if i cane it
do all 3
Offline dubslug
Re: Engine mounts
« Reply #12 on: 10 November 2004, 21:48 »
sounds like i got one left to do then lol
1992 pearl grey 8v
Offline rustynuts
  • God is a DJ
Re: Engine mounts
« Reply #13 on: 10 November 2004, 21:58 »
This is what needs to be done, remove 3 bolts from the top connecting the supposrting arm to the mount, then its a matter of supporting the engine with a jack. The arm needs to be removed to give space to get the mount out. Then undo the central bolt if you can get to it properly with the tools you have. Allow for lots of skin loss and ear muffs for the neighbours so they don't hear the swearing!
Most the time its the front mount that causes the most movement. Always try that one first.
Offline Tucker
Re: Engine mounts
« Reply #14 on: 11 November 2004, 11:41 »
Top job, not done it yet as it was dark by the time i got home, going to do it on sat, Will do the front first ;) then she whats she like
thanks for the help people 8)
Tucker
« Last Edit: 11 November 2004, 11:48 by Tucker »
http://i10.photobucket.com/albums/a109/sydney04/mk116vsmallpic.jpg
Sig too large, see forum guidelines - Admin.
Offline benjam_in
Re: Engine mounts
« Reply #15 on: 11 November 2004, 11:47 »
front ones quite simple! compared to the rear one! go for it it makes so much difference!
Golf Mk2 Gti 1988
Offline Tucker
Re: Engine mounts
« Reply #16 on: 11 November 2004, 11:51 »
I have done a front one on my mates a month or two ago and was a pi$$ of pi$$, I just needed a bit of advice on the rear as i have never done one befor.
I'm hoping that it make a big differance so i can take the rear back and some some money back ;D
Tucker
Offline benjam_in
Re: Engine mounts
« Reply #17 on: 11 November 2004, 12:07 »
yea i changed a subframe n steering rack before n that envolved changing the rear engine mount! but was a bit more hardcore! lol also done my rear engine mount this summer! where abouts r u located mate?
Golf Mk2 Gti 1988
Offline Tucker
Re: Engine mounts
« Reply #18 on: 11 November 2004, 12:09 »
Down south in Devon
Offline rustynuts
  • God is a DJ
Re: Engine mounts
« Reply #19 on: 12 November 2004, 23:44 »
Removing the drivers side drive shaft makes doing the back one a lot easier as gives a lot more space. Just a bit of advice i could have done with before doing mine.
