Author Topic: temp gauge on agu  (Read 2133 times)
Offline aaran
temp gauge on agu
« on: 16 March 2010, 20:16 »
what should the temp gauge be on an agu once warm?
mine only ever seems to hit dead on 90 degress once been run and sat in traffic for a few mins, when im driving it it seems to be between 80-85 degrees, never on 90?
Offline Rhyso
Re: temp gauge on agu
« Reply #1 on: 16 March 2010, 20:19 »
change your thermostat
Offline bobbarley
  • I'm kind of a big deal...
« Reply #2 on: 16 March 2010, 20:23 »
I wouldn't worry until it goes OVER 90!  :grin:
Offline richw911
« Reply #3 on: 16 March 2010, 22:30 »
Should sit dead on 90 as soon as its up to temp.
As said new stat time.
http://www.golfgtiforum.co.uk/index.php?topic=101783.0
Have you scanned it for fault codes?
Offline G60GTI16V
  • GTI Mk1, 2, 3, 4 now VRS Hell Yea!
« Reply #4 on: 16 March 2010, 22:55 »
def the stat changed mine now fine
Offline aaran
« Reply #5 on: 17 March 2010, 12:28 »
thnaks guys jsut got a cheap fault code reader so will get it fault read and grab a thermostat. i work in a morotfactors so it will work out next to nothing anyway :)
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #6 on: 17 March 2010, 12:42 »
as has been said replace your thermostat and also maybe worth replacing the coolant temp sender (cts) at the same time as its cheap enough and is literally a 5min job if that  :wink:
2000 Mkiv GTi 1.8T AGU
Offline PishY
« Reply #7 on: 17 March 2010, 17:51 »
changed myne and the temp sensor and its sorted it, stays on 90 now when i drive about.
used to drop off when driving, but not anymore! :)
Offline D4VEY01
  • 1999 GTI 1.8T AGU BLACK
« Reply #8 on: 21 March 2010, 16:48 »
Are these cheap from the dealer?..mines an AGU an has just started doin the same thing,keeps droppin to halfway between cold and 90 deg when i go on the expressway.
cheers dave
1999 : GTI : 1.8T : AGU : SPEC 1 R-TECH REMAP : BOSCH SUPER 4 : FORGE TIP : SILICONE TURBO HOSE KIT : 18" RS4 ALLOYS : -30MM ADJ SPAX SHOCKS/SPRINGS : FORGE 007P D/V (YELLOW) : MILLTEK CAT BACK RES 4MOTION : POWERFLEX DOG BONE BUSHES : PIPERCROSS FILTER : FORGE ACTUATOR (YELLOW) :
Offline Purely VAG
« Reply #9 on: 21 March 2010, 20:37 »
Mines same pal on my AGU, i've got to price up a stat tomorrow.
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
