Author Topic: temp gauge on agu  (Read 2126 times)
Offline northeast_gti-t
  • "1.8T AGU"
Re: temp gauge on agu
« Reply #10 on: 21 March 2010, 21:22 »
as has been said replace your thermostat and also maybe worth replacing the coolant temp sender (cts) at the same time as its cheap enough and is literally a 5min job if that  :wink:
Are these cheap from the dealer?..mines an AGU an has just started doin the same thing,keeps droppin to halfway between cold and 90 deg when i go on the expressway.
cheers dave
is worth changing both then really yes cheap enough from vw but give tps a try iirc i got a stat,o'ring,coolant temp sensor and clip for under £30 obviously some G12++ coolant on top around 3 litres
2000 Mkiv GTi 1.8T AGU
Offline Purely VAG
« Reply #11 on: 21 March 2010, 22:10 »
2 pin CTS from VW is £24
4 Pin CTS £32
Arent cheap, TPS must give good discount on that.
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
  • "1.8T AGU"
« Reply #12 on: 21 March 2010, 22:23 »
4 Pin CTS £32
they do compared with vw  :wink: :smiley:
Offline aaran
« Reply #13 on: 22 March 2010, 12:30 »
stats under £3 to me and i wont say how much the temp sensor is  :evil: will see what brand is in the box when i get back to work and have a look.
red longlife antifreeze for vw right?
Offline G60GTI16V
  • GTI Mk1, 2, 3, 4 now VRS Hell Yea!
« Reply #14 on: 22 March 2010, 15:13 »
NO its G12 even says it on the header tank  :smug:
i get free bottles of this when im due for a change from my lovely vag dealer  :evil:
Offline Purely VAG
« Reply #15 on: 22 March 2010, 19:04 »
Correct.
Ordered my stat today, comes tomorrow.
Offline D4VEY01
  • 1999 GTI 1.8T AGU BLACK
« Reply #16 on: 24 March 2010, 21:29 »
Went dealers and got stat,sensor and o rings.Sensor was a 5 min fit..Stat about an hour coolant included in that..Small 5mm allen key and 5mm ball end allen key essential no dramas.
1999 : GTI : 1.8T : AGU : SPEC 1 R-TECH REMAP : BOSCH SUPER 4 : FORGE TIP : SILICONE TURBO HOSE KIT : 18" RS4 ALLOYS : -30MM ADJ SPAX SHOCKS/SPRINGS : FORGE 007P D/V (YELLOW) : MILLTEK CAT BACK RES 4MOTION : POWERFLEX DOG BONE BUSHES : PIPERCROSS FILTER : FORGE ACTUATOR (YELLOW) :
