Author Topic: Dom069 - My 8v Story So Far - Deposit Taken :(  (Read 552967 times)
Offline dom
  • Back in a Mk4
Re: Dom069 - My Mk3 Story So Far, A Bit of ICE added
« Reply #380 on: 05 November 2010, 09:59 »
Ha ha cool....... I've made that mistake before with a switch.. Have you switch the sub because you couldn't be bothered to wire up the remote wire?  :grin:
Partly :lipsrsealed: I did wire up the remote wire but it was a dodgy connection so the sub was flicking on/off, but also partly because the g/f. I think her words were something along the line of 'don't get me wrong, I like the seat vibrating, just not all the time'  :grin:
So all in all it seemed like a good idea to just wire in a switch, simple and effective  :smiley:
Offline SoundillusioN
« Reply #381 on: 05 November 2010, 10:30 »
Yeah its nice and flexible at least... i used to have a sub with a controller, Just a knob where you could adjust the input to the sub from the dash... was very handy as it could be a pain having go to the boot all the the time to adjust levels... hmmm, wonder if stuff like that is still available, i'm sure it must be.
« Reply #382 on: 05 November 2010, 10:32 »
ah ha... found one....
Offline dom
  • Back in a Mk4
« Reply #383 on: 05 November 2010, 10:39 »
You couldn't have found that yesterday could you  :rolleyes: :grin:
Looks like a much better idea than a toggle switch, why didn't I think of that?! :embarassed:
« Reply #384 on: 05 November 2010, 10:47 »
Well i didnt know you were going to fit a switch.... you can still fit one though, then it will be a super flexible setup.  On off and in dash level adjust.   :cool:
Offline dom
  • Back in a Mk4
« Reply #385 on: 05 November 2010, 10:53 »
Good thinking, how would you go about wiring that in then? What would you have to tap it into?  :smiley:
« Reply #386 on: 05 November 2010, 10:59 »
it just goes in between the phono Line out/Sub out from your head unit to the sub.. so all you will need is a short set of phono leads from your stereo to this, then the other connections go from this to the long phono's to your sub.. no power required.. hope that made sense.  :smiley:
« Last Edit: 05 November 2010, 11:02 by SoundillusioN »
Offline Dec
« Reply #387 on: 05 November 2010, 13:41 »
I had a really old 10" sub in my mk2 that had one of those adjuster switches :cool:
Does the head unit not have a sub on/off option? :undecided: Thought that was why they don't really have hard switches anymore.
Offline Shady Pioneer
  • graphic designer.
« Reply #388 on: 05 November 2010, 13:44 »
Does you headunit not have a subwoofer adjuster built in?
« Reply #389 on: 05 November 2010, 14:07 »
Ha, yeah most head units do but you always have to go through a menu to get to it, there's nowt better than having an easy access knob!  :grin:
