Author Topic: TDI 130 Air / Whooshing noise on acceleration  (Read 13627 times)
Offline golfwannabe
« on: 28 February 2010, 16:04 »
Hi Guy's,
Its been a wee while but I'm back this time in a Golf TDI 130!! I've noticed that I've got a kind of air sucking / whooshing on acceleration - can hear it with the window open - any ideas????
Offline Rhyso
Re: TDI 130 Air / Whooshing noise on acceleration
« Reply #1 on: 28 February 2010, 17:29 »
whats the performance like??
My money would be on a boost leak
Offline mcgee9t2
« Reply #2 on: 28 February 2010, 19:17 »
sure its not the window
haha nah
could be a whole host of things. were does it seem to be coming from? exhauste? engine?
Offline golfwannabe
« Reply #3 on: 28 February 2010, 20:54 »
It bloody flies when you give you some to be honest but I do get plumes of sh!t coming out of the back end.
The noise is coming from the engine and with the drivers window open it's very noticeable - Put it in 5th tonight at about 30-40mph and could still hear it. It sounds like it's turbo related or induction related????
Offline Rhyso
« Reply #4 on: 28 February 2010, 20:57 »
smoke is normal - its the quantity you need to be worried about lol
what's it like with the window closed?? I had a boost leak and it sounded like the air was rushing in through the vents
Stick you head under the bonnet and check for any obvious signs of loose pipes
Also look down by the drivers side wheel arch as some of the pipework runs along there
Offline golfwannabe
« Reply #5 on: 28 February 2010, 21:24 »
Whats a dodgy amount of smoke to look out for?? I'm talking a fair old amount as in if i look through the rear view mirror it's really bloody noticeable  :shocked:
The hissing / air / whooshing noise is really bloody loud with the drivers window open but can't say I can hear it with it shut. My bro had a drive tonight without me mentioning it and he turned to me and said 'what the f**k is that noise?'
Offline richandhazel
« Reply #6 on: 01 March 2010, 08:58 »
I was going to ask whether you are getting a lot of smoke at the same time as whooshing noise.
Almost certainly an air leak as Rhyso says.
Check all your hose connections, especially around the air cooler/heat exchanger. It will be somewhere between the turbo outlet and the inlet manifold.
Offline golfwannabe
« Reply #7 on: 01 March 2010, 14:03 »
Cheers for the reply.
Where do I need to look for these leaks? I've only had the car a few days and I don't where things are located in the bay (turbo, intercooler etc)
Cheers for the help.
Offline Rhyso
« Reply #8 on: 01 March 2010, 14:07 »
On your car where my big blue pipe is, you'll find an equivalent black plastic pipe
Your intercooler is located behind the lower front grill on the drivers side
From the back of that runs your pancake pipe inside the drivers wheel arch into a red turbo pipe into the turbo
Check all the connections - you might find that the lugs are worn and the only option is to replace the pipe.  Or you might be lucky and just the o-rings are perished - each one is about £2 each from the dealers
Offline golfwannabe
« Reply #9 on: 01 March 2010, 14:19 »
Cheers Mate. That's bang on!
