Author Topic: TDI 130 Air / Whooshing noise on acceleration  (Read 13606 times)
Offline Rhyso
Re: TDI 130 Air / Whooshing noise on acceleration
« Reply #10 on: 01 March 2010, 14:23 »
Cheers Mate. That's bang on!
No worries  :smiley:  Hopefully that should help pinpoint the problem  :smiley:
My money would be on either a loose pipe or a split in the red turbo hose (which is what I've had)  Lets hope its not the red hose as they are a cool £100 from the dealers  :cry: :cry:
Offline golfwannabe
« Reply #11 on: 01 March 2010, 18:51 »
Really?? Bloody hell - a lot of wonga for a hose!!  :cry:
I think it may be the red hose which runs down through the drivers side wheel arch for 2 reasons;
A) I'm bloody unlucky with cars and it'll always be the most expensive option.
B) The whooshing / hissing / air noise that I hear with drivers window open is coming from around that area and apparently the black smoke is a characteristic of that probelm? Is that correct?
Offline Rhyso
« Reply #12 on: 01 March 2010, 19:40 »
A) I feel your pain on that one lol
B) either the intercooler or that red pipe - lets hope its just a loose connection :afro:  Thick black smoke is a sure sign of a boost leak
Offline golfwannabe
« Reply #13 on: 27 March 2010, 13:56 »
Ok, So I've had my car checked today and the Intercooler is f**ked! We did a smoke test and it's billowing out. sh!t loads of oil too. Looks like previous owner has put it up a grass verge and damaged it.
VW want £250 for a new one. Anyone recommend a VW refurbs?? Can I upgrade this for something better seeing as it needs replacing? If so What can I upgrade too?
I also need a new Power Steering pump - What approx price do these go for?
Offline T_J_G
« Reply #14 on: 27 March 2010, 14:11 »
You could upgrade to an Allard FMIC but apaprently they're a lot of hassle to fit.
Otherwise eBay, scrappies but make sure you test it before it goes on.
Offline Rhyso
« Reply #15 on: 27 March 2010, 14:21 »
ooo not good
Look on Ebay for a 2nd hand one - I picked up one for £30
Other options are Allard or Forge but both are the far side of £500 each..........
Offline golfwannabe
« Reply #16 on: 27 March 2010, 14:32 »
Cheers, Will have a look.
For £30 is everything ok with it?
Ideally want some kind of warranty in case its faulty...
Offline Rhyso
« Reply #17 on: 27 March 2010, 14:44 »
Pressure tested it before it went on the car  :wink:  There is some oil around it but I'm hoping to clean that up when i get round to fitting my catch tank
Make sure its from a 130 though - all the rest are different fitments.  Don't forget to search under Bora too - that's how I found mine
Offline golfwannabe
« Reply #18 on: 27 March 2010, 15:01 »
Cheers mate.
