Author Topic: weird brake fault HELP(pedal down to floor)  (Read 2516 times)
Offline gti_shaun
« on: 27 February 2010, 19:10 »
HI all, right when i have been on lock a few times say getting out of a parking space i set off then go to brake and the pedal goes to floor,them ok on second application, its like a front wheel bearing is calapsed and pushing the caliper back(check them)
its the same fault as this http://www.golfgtiforum.co.uk/index.php?topic=102205.0
ive PM'd this guy, just waiting on reply, just wondered if anyone had this?
« Last Edit: 27 February 2010, 19:16 by gti_shaun »
Offline meano73
Re: weird brake fault HELP(pedal down to floor)
« Reply #1 on: 27 February 2010, 20:11 »
allright mate.same thing has happened to me.cant remember wich lock i put on but its happened to me in the past but not recently.the noise is still there but the brake pedal thing hasnt happened for a while.not wheel bearings as had both of them replaced recently.hope you get to the bottom of it and if you do will you post it so others can see what was wrong.cheers.
« Reply #2 on: 28 February 2010, 00:09 »
Master cylinder.
Offline richw911
« Reply #3 on: 28 February 2010, 10:58 »
Offline gti_shaun
« Reply #4 on: 28 February 2010, 11:45 »
but why after being on lock, and whats the noise, (a knock like the other one who has the same fault)
Offline BaV
  • 2001 Golf GTI 1.8T AUM
« Reply #5 on: 28 February 2010, 12:44 »
Have you had your camblet done lately? What engine code do you have?  I would bet 90% it Wont be master cylinder.
Offline michaelnabbi
« Reply #6 on: 28 February 2010, 17:04 »
you might find that you have a damaged flexi hose when you put it on a lock hose kinks and forces fluid back up to master cylinder 1 st push on the pedal re primes the caliper and second push is fine
Offline gti_shaun
« Reply #7 on: 28 February 2010, 18:10 »
i have put the engine in(was a 2.0 8valve) and yeah i have done the cam belt why?
Offline BaV
« Reply #8 on: 28 February 2010, 19:33 »
Ok not to worry then should be ok.
On a lot of mk4 platform cars there is a brake hose that runs alongside the plastic cover that you have to remove to do the cambelt.  I have read lots of threads where people get there cambelt done and the garage bends the hose out of the way and forgets to bend it back where is should be resulting in intermittent brake failure untill the hose is bent back to where it should be.  I dont know too much about this but as said i have read it a few times now.  Apparently the master cylinders are bullet proof
Offline Matty-MK3
  • Automatic boats FTW.
« Reply #9 on: 28 February 2010, 23:08 »
This, check this, if not could well be Master Cylinder.
Golf MK3 1.8 auto and I didn't pay a grand for the "priveledge" :grin:, auto windows all round and a AC. Oh and I've got a luggage net you pricks!
Does that make my willy look bigger?
Oh yeah it's called Helda or something....
