Author Topic: 280mm Discs  (Read 9475 times)
Re: 280mm Discs
« Reply #40 on: 26 February 2010, 10:49 »
ibiza with 280mm uses G60 pads, 256 uses 16v pads ;)
Offline cняis
Re: 280mm Discs
« Reply #41 on: 26 February 2010, 23:01 »
:afro:  cheers RJ!
Offline georgenewman1
Re: 280mm Discs
« Reply #42 on: 27 February 2010, 11:39 »
so tell me if i have this rite, i have a 1990 16v with 256 disks on it, if i want to go to 280all i need is the calliper carriers and to make sure i get the 16mm pads, is that rite??
Offline sprout99
Re: 280mm Discs
« Reply #43 on: 27 February 2010, 22:37 »
i had to take 3mm off each slide bolt to allow calliper to fit
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Re: 280mm Discs
« Reply #44 on: 28 February 2010, 09:15 »
ha lush i shal get searching then  :smiley:
Re: 280mm Discs
« Reply #45 on: 28 February 2010, 13:19 »
ive found a set of vr6 calipers and carriers on ebay but they say there 288, will these fit standard mk2 16v hubs and are 4 stud disks available for these?????
Offline sprout99
Re: 280mm Discs
« Reply #46 on: 01 March 2010, 07:57 »
no....mk3 parts need to be before 1995....288's won't fit.
Oak green mk2
V50 D5 Sportwagon
Offline Neo Badness
  • Feet are for pedals
Re: 280mm Discs
« Reply #47 on: 01 March 2010, 12:41 »
FM those carrier bolks were an absolute swine to get out.
Ended up having to heat them out.
Who's bright idea was it to put hex bolts on rear carriers!?
Offline Mr Blue
Re: 280mm Discs
« Reply #48 on: 01 March 2010, 22:31 »
Great info from the man once again. Badly need to update my brakes.
Also worth taking the 15'' space saver spare wheel to fit over the brakes. I got mine out of a corrado g60. Not sure if seat's have space savers though. :)
Re: 280mm Discs
« Reply #49 on: 02 March 2010, 11:12 »
well really if you get a front flat you shjould put space saver on the back and put good rear wheel on the front, dont want a space saver on the front if you can help it!
