Author Topic: 280mm Discs  (Read 9476 times)
Offline sprout99
Re: 280mm Discs
« Reply #30 on: 22 February 2010, 14:50 »
nope....don't need to since caliper is 256mm
tried brakes and they feel very good.
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline Neo Badness
  • Feet are for pedals
Re: 280mm Discs
« Reply #31 on: 23 February 2010, 10:31 »
Is there any issue using calipers that were once ABS on a none ABS car?
Offline sprout99
Re: 280mm Discs
« Reply #32 on: 23 February 2010, 11:55 »
no idea...wouldn't imagine so
Oak green mk2
V50 D5 Sportwagon
Offline Neo Badness
Re: 280mm Discs
« Reply #33 on: 23 February 2010, 12:19 »
Sound enough, will have a play :wink:
Re: 280mm Discs
« Reply #34 on: 23 February 2010, 15:29 »
no there isnt, 280 ABS calipers are same as 280 non-abs calipers
Offline Neo Badness
Re: 280mm Discs
« Reply #35 on: 24 February 2010, 23:00 »
Coolio.
Offline cняis
Re: 280mm Discs
« Reply #36 on: 24 February 2010, 23:47 »
anyone know if the ibiza 16v setup needs 16mm or 19mm thick pads? i've come across both listed!
Offline sprout99
Re: 280mm Discs
« Reply #37 on: 25 February 2010, 07:53 »
i would guess 19mm.....i have used the std Golf 16V versions on mine which are 16mm
as i'm using the original callipers with modded slide bolts
Oak green mk2
V50 D5 Sportwagon
Re: 280mm Discs
« Reply #38 on: 25 February 2010, 12:01 »
depends which ibiza 16v you're on about! they had both 256 and 280mm brakes, depending on if its 1.8 or 2.0 16v.
Offline cняis
Re: 280mm Discs
« Reply #39 on: 25 February 2010, 19:22 »
2.0 16v with 280mm discs  :smiley:
