Author Topic: 280mm Discs  (Read 9499 times)
Offline LazyLunatic
  • MK3 20VT Project
Re: 280mm Discs
« Reply #10 on: 16 February 2010, 16:32 »
just buy some new pads. might as well :)
seat ibiza sport 16v or gti 16v use the 280mm set up :smiley:
Sweet, I have an M reg 16v golf gti so I'll be scalping the brake setup from that.
yeah, but only the calipers and carriers if you staying 4 stud :afro:
Offline Neo Badness
  • Feet are for pedals
Re: 280mm Discs
« Reply #11 on: 16 February 2010, 17:11 »
Ta, yeah, considered the wide track option but has been left alone due to insurance issues...
Offline hayescappa
  • Nearly there!
Re: 280mm Discs
« Reply #12 on: 16 February 2010, 21:49 »
Heres my set
fitted passat hubs, from 1990 car
Mk3 Golf Gti Calipers, pre 95 i think.
Diamond Braded hoses and black diamond discs.
Didn't measure the pads, but they look like 19mm.
Offline sprout99
Re: 280mm Discs
« Reply #13 on: 17 February 2010, 07:52 »
thanks for all the advice !  :grin:
I spoke to guy at VW spares yesterday. He mentioned that there might be a clearnace issue
with BBS RA's and the bigger G60 callipers??
I'll get the mk3 callipers and carriers off me mate and have a look at what i can do.
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline sprout99
Re: 280mm Discs
« Reply #14 on: 17 February 2010, 09:28 »
will the 280 conversion work with std BBS RA's?
Oak green mk2
V50 D5 Sportwagon
Re: 280mm Discs
« Reply #15 on: 17 February 2010, 09:54 »
The 15" RA comes in 2 different offsets, 1 size fits, other needs a thin spacer.
« Last Edit: 17 February 2010, 10:44 by rubjonny »
Offline LazyLunatic
  • MK3 20VT Project
Re: 280mm Discs
« Reply #16 on: 17 February 2010, 10:05 »
14" ra's will not fit over the brakes but 15's will be fine :)
Re: 280mm Discs
« Reply #17 on: 17 February 2010, 10:44 »
as above, 2 offsets of 15" RAs, 1 set clears other needs a thin spacer ;)
Offline sprout99
Re: 280mm Discs
« Reply #18 on: 17 February 2010, 10:46 »
i had a look last night - there's a good 20mm between calliper and wheel
car has original wheels .....ET28 possibly?
i'm going to pick up carriers tonight. Might bring them to work and turn the guide pins down
on lathe. bit more accurate than grinding
Oak green mk2
V50 D5 Sportwagon
Re: 280mm Discs
« Reply #19 on: 17 February 2010, 11:19 »
iirc the 2 sizes are ET35 and 38? or 33 and 35... Will do some searching
edit: though this is only an issue with proper G60 callipers, the 256mm calipers that you'll be using will clear just fine :)
« Last Edit: 17 February 2010, 11:43 by rubjonny »
