Author Topic: 280mm Discs  (Read 9516 times)
Offline sprout99
Re: 280mm Discs
« Reply #20 on: 17 February 2010, 12:06 »
iirc the 2 sizes are ET35 and 38? or 33 and 35... Will do some searching
edit: though this is only an issue with proper G60 callipers, the 256mm calipers that you'll be using will clear just fine :)
but will need some monor tweaks ......to carrier guide pins.
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Re: 280mm Discs
« Reply #21 on: 17 February 2010, 13:01 »
yeah in order to get the calipers to fit over the discs, what i meant was either size of BBS RA will clear the 256mm calipers without any issues.
After some research, the 2 sizes are:
191 601 025 AE - 6.5x15 ET33
165 601 025 - 6x15 ET35
not sure which ones clear the G60s, but I'd hazard a guess it would be the 6.5J ones as they're a lower offset.
Offline sprout99
Re: 280mm Discs
« Reply #22 on: 17 February 2010, 13:59 »
i'll look tonight - the offser is stamped on outside of wheels
Oak green mk2
V50 D5 Sportwagon
Offline sprout99
Re: 280mm Discs
« Reply #23 on: 17 February 2010, 22:02 »
mine are 6j x 15 ET35
There is loads of room around calliper but any bigger on bigger discs might not fit.
Got carriers.....need to paint them and find slide bolts
Oak green mk2
V50 D5 Sportwagon
Offline sprout99
Re: 280mm Discs
« Reply #24 on: 19 February 2010, 10:51 »
bits have arrived
280mm discs
std 16v pads (16mm thick)
280 carriers currently in garage at home painted black
fingers crossed i hit no snags......
angle grinder at the ready for slide bolts modding !
Oak green mk2
V50 D5 Sportwagon
Offline RWMT
  • 16v
Re: 280mm Discs
« Reply #25 on: 19 February 2010, 11:45 »
Keep us posted with your progress.
I too have 6j x 15 ET35 RAs and would be interested to hear if you have any clearance issues.
Offline sprout99
Re: 280mm Discs
« Reply #26 on: 19 February 2010, 13:19 »
i'll be very p155ed off if they don't fit !
my old mk3 ibiza Sport had 15" wheels and 280mm brakes
Oak green mk2
V50 D5 Sportwagon
Offline cняis
Re: 280mm Discs
« Reply #27 on: 19 February 2010, 19:22 »
i have the ibiza sport 280mm set up with 15" MIM 1000s and there are no issues  :afro:
Offline sprout99
Re: 280mm Discs
« Reply #28 on: 19 February 2010, 22:35 »
it's fitted......
grinding down the slide pins was a pain but the std callipers and 280 carriers are in place.
there is very little clearance but no rubbing. Brakes feel very positive so far and should get better
Oak green mk2
V50 D5 Sportwagon
Offline russ-vdub
  • Once a Dub, Always a Dub
Re: 280mm Discs
« Reply #29 on: 22 February 2010, 11:49 »
Did you change the master cylinder?
