Author Topic: Starting woes  (Read 1740 times)
Offline dragonfly
Starting woes
« on: 14 February 2010, 11:00 »
Thought my starting issues were all behind me! When I try and start my 16v from cold if refuses to start but does after the third attempt (a couple of pumps of the throttle). The fuel pump primes, the engine turns over and when I turn the key in the ignition back (to the off position) it splutters like I've have stalled it.
The cars been serviced - new leads, coil, battery, plugs, cam cover gasket replaced, fuel filter and dizzy seal replaced.
When the car is running there's no problems - runs sweet as a nut. If I switch is off, it starts no problem.
Help!
Offline Gloves88
Re: Starting woes
« Reply #1 on: 14 February 2010, 14:21 »
Does it do this every time you go to start it?
I've had similar issues with mine.
What seemed to cause it on mine was if it hadn't been used for a few days moisture would build up on the engine preventing the plugs from sparking properly. Bit of damp start around the plugs and it would fire up fine.
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Starting woes
« Reply #2 on: 14 February 2010, 15:14 »
If that's the case I would spray all the electrics with WD40 when its warmed up and dried out!!...
For More Info Click To See;
Offline dragonfly
Re: Starting woes
« Reply #3 on: 14 February 2010, 20:17 »
I doubt it is damp as it seems to start the third time. There is not tell tale signs of damp either - nothing inside the dizzy.
It's driving me nuts!
Offline Alec
Re: Starting woes
« Reply #4 on: 14 February 2010, 21:09 »
What injection system is it running?
Offline dragonfly
Re: Starting woes
« Reply #5 on: 14 February 2010, 21:13 »
It's a 1992 - K-Jetronic.
Offline Alec
Re: Starting woes
« Reply #6 on: 14 February 2010, 21:17 »
Think I read recently that the metering head can be adjusted so it starts better when cold by letting a bit more fuel in, alan key kinda screw needs to be turned like half a turn clockwise I think.
Cant remember what post I saw it in or who posted the tip but I think it worked
Would be very easy to do just to see if it works
Offline dragonfly
Re: Starting woes
« Reply #7 on: 14 February 2010, 21:24 »
Interesting - will give that a go thanks! Hopefully it will solve my starting issue!
Offline Alec
Re: Starting woes
« Reply #8 on: 14 February 2010, 21:26 »
Yeah give it a whirl, can easily turn the screw back if it doesnt do anything.
Dont think it needs to be turned too much though mate, just half a turn at first and see what happens
Good luck  :smiley:
Offline dragonfly
Re: Starting woes
« Reply #9 on: 14 February 2010, 21:28 »
Never had this problem with my 8v's!
