Author Topic: Starting woes  (Read 1748 times)
Offline Alec
Re: Starting woes
« Reply #10 on: 14 February 2010, 21:32 »
8valve for the win!!! Even though mine runs like a sick pig when cold and nothing I do seems to cure it  :lipsrsealed:
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Starting woes
« Reply #11 on: 15 February 2010, 01:29 »
Just a stab in the dark... Could it be the starter motor?
Could be a totally dumb ass reply, but you seem to have replaced everything else....
For More Info Click To See;
Re: Starting woes
« Reply #12 on: 15 February 2010, 09:46 »
if it feels like its going to start just as you release the key, it could be a fault with the ign switch. to confirm this either way run a wire from the battery +ve to terminal 15 on the coil. Terminal 15 is where the black wires run to. obviously take care when doing this, and dont leave the wire there all the time either.
Offline dragonfly
Re: Starting woes
« Reply #13 on: 15 February 2010, 09:51 »
Started the car this morning a few pump of the pedal and it fired up second time. There was a metalic clatter but that could be the down pipe which needs replacing. Could it be the plunger?
