Author Topic: uprated headlight loom  (Read 5392 times)
Offline leeroy20vt
  • h reg mk2 gti
« on: 02 February 2010, 17:21 »
i have searched on this and most people are sayin there gettin around 10.5 volts thru there loom i have just checked mine and with engine running im gettin 12.5 volts
so my question is it worth doin the uprated loom for an extra volt
cheers
Offline dubber36
Re: uprated headlight loom
« Reply #1 on: 02 February 2010, 17:54 »
The difference between 10.5 and 12.5 is nearly 20%, so considering how poor the standard lights are, I would say every bit helps.
Offline leeroy20vt
  • h reg mk2 gti
« Reply #2 on: 02 February 2010, 20:19 »
i guess ur rite but would another volt and a half make much dfference
Offline ianmaxtec
« Reply #3 on: 02 February 2010, 20:26 »
I had problems with my lights, and after a bit of research realised that all the switching was done via the stalk (and not vis a relay). I used the plug a the back of the head lights to trigger a new relay (which took power from the battery via a new fuse), and the difference was amazing...BIG BRIGHT LIGHTS, well worth doing, and costs very little.
Offline JMallows
« Reply #4 on: 02 February 2010, 20:36 »
I used to get around 12.7V at the lights before i did my loom, and i thought the same thing as you, is it worth it. I did it, and i know for a fact that it IS definately worth it! Basically, the thicker, shorter wires have lower resistance, and since the voltage from the battery is the same, the current will increase. This means more power to the bulbs, hence brighter.
In short, its worth doing...
A clever person solves a problem. A wise person avoids it.
Offline leeroy20vt
  • h reg mk2 gti
« Reply #5 on: 02 February 2010, 20:57 »
cheers for that well i got all the bits today then checked it and thought wat a waste of money shall get on it tommorow and get some pics
did u 2 do dipped and main beam or just dipped
Offline h8v
« Reply #6 on: 02 February 2010, 21:00 »
Sorry to be scientific, but I believe the percentage increase is not proportional to the voltage, but to the voltage squared.  So 12 volts increased to 14 volts; the power increase is 144 to 196 which is 36 percent increase!!!!!!
Anyway, try conecting a thick wire direct from the battery to the headlight main (or dipped) beam directly and check out the difference.  :smiley:
Suck it and see.
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #7 on: 02 February 2010, 22:36 »
Suck it and see.
This gets my post of the night award, for geekiness :nerd: :nerd: :nerd: :nerd:
 :grin:
Thom
Offline dan_apps
  • too low for british roads!
« Reply #8 on: 02 February 2010, 22:40 »
Suck it and see.
 :grin:
Thom
good maths skills :afro:
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #9 on: 02 February 2010, 22:42 »
Lee Stick up some pics and a list of parts!!  :smug:
Ta Mate!! :cool:
For More Info Click To See;
