Author Topic: uprated headlight loom  (Read 5393 times)
Offline weazgti
Re: uprated headlight loom
« Reply #10 on: 02 February 2010, 22:54 »
cheers for that well i got all the bits today then checked it and thought wat a waste of money shall get on it tommorow and get some pics
did u 2 do dipped and main beam or just dipped
Lee Stick up some pics and a list of parts!!  :smug:
Ta Mate!! :cool:
I did my dipped only and it makes main beam look crap and really yellow, you might aswell do both to get it good.
Offline dubber36
« Reply #11 on: 03 February 2010, 08:16 »
If you do dip and main, you'll have to your spots as well.
Offline leeroy20vt
  • h reg mk2 gti
« Reply #12 on: 03 February 2010, 09:18 »
[/quote
i havent go spots on mine but im guessing if i do main it will automaticly do spots for if/when i put them in
will get some pics up of parts ect all i got so far is is 2 relays some connectors and a few bits of wire lol
if i do main as well will just need to double what i got
« Reply #13 on: 03 February 2010, 10:41 »
original spots are spliced into the H4 connectors, so you dont HAVE to relay them they'll still work even if main headlight plugs are completly disconnected.  thing is the spots are still pretty damn bright even if not relayed, obv be brighter if you do. comes down to how often you use your main beams, relaying the dipped beams is prob gonna see the most benefid day to day, unless you live out in the countryside and do a lot of night driving.
Offline leeroy20vt
  • h reg mk2 gti
« Reply #14 on: 04 February 2010, 19:22 »
cheers rj
i still havent got round to doin this weather has been pants blah blah lol but have also been getting a few bits ready for rolling road on monday cant wait to get her set up properly been a long 500 miles i can tell ya
Offline RWMT
  • 16v
« Reply #15 on: 04 February 2010, 20:48 »
Any thoughts on where the best place to buy all of the relevant compontents is?  I popped into Halfrauds the other day and saw that fused relays were about £7.50 each!  :shocked:
A quick calculation, and I reckon that you are looking at £25 all in for compontents!  There must be somewhere cheaper...
Offline leeroy20vt
  • h reg mk2 gti
« Reply #16 on: 04 February 2010, 20:58 »
i got mine from a local motorfactors if there still called that the relays were just under 3.50 each i spent 10.30 or somethink like that which didnt think was do bad
all u need is 30amp relays might be worth lookin on the bay
Offline weazgti
« Reply #17 on: 04 February 2010, 21:13 »
Maplins.
Maplin relays £1.98 each
Fuse holder bout £5 i think
Connecters bout £3 for a bag.
Dunno bout wire because i was tight and used some i had allready.
Offline danny_p
« Reply #18 on: 04 February 2010, 21:44 »
go scrappy and aquire pocketfull of relays,   IMO your best off soldering to the relay tags and dipping in resin aftermarket rellays holders are crap and crimps can fall off.
all the VW's have gone bar 1.
Offline leeroy20vt
  • h reg mk2 gti
« Reply #19 on: 04 February 2010, 22:09 »
cheers danny i think it may have been one of ur how tos i see with resin round them
im not sure were to mount the relays either im sure somethink will come up
