Author Topic: Rear washer fault  (Read 1971 times)
Offline jonboy90
Rear washer fault
« on: 31 December 2009, 15:39 »
Could anyone point me in the right direction or does anyone have any advice as to my problem. the rear wiper works but the washer jet does not. could it be the nossel is blocked, if so what is the best way to clean it or could the hose be disconnected??? how can i check if the hose is still connected??
any help would be gratefully received cheers
Offline jonboy90
Re: Rear washer fault
« Reply #1 on: 31 December 2009, 16:12 »
just been out to check. i can hear the pump trying to spray water thru the back jets but there is only a small amount dribbling out the jet. how do i get to the back of the unit to check the pipes are ok?
Offline Hurdy
« Reply #2 on: 31 December 2009, 16:25 »
The interior trim for the boot is fixed by two screws inside the hand pull recesses. Once these are removed, take off the light access covers at each side (just pull out). Then you need to be fairly brave and pull off the main trim using the two bulb access points for purchase. The trim is held in place by about 8 metal clips and two long plastic ones, all these simply pop undone when you pull firmly. Once one clip has popped, follow the trimaround to pop the rest. When the trim is off you can see the full workings for the washer jet.  :cool:
Seat Leon Cupra Black 290 DSG
Offline jonboy90
« Reply #3 on: 31 December 2009, 16:30 »
Thanks Hurdy. Ill give it a go tomorrow when i can see what in doing. i cant see any water escaping so i dont think its a loose hose but ill take off the cover and give it a once over. Is this a common ploblem ? it was working fine untill  a few weeks ago.
Offline Hurdy
« Reply #4 on: 31 December 2009, 16:36 »
I've known a few block to a dribble in the past. The best way to prevent it is to buy a washer top-up filter/mesh to catch any deposits that may lurk in your filling jug/watering can/bottle etc :smiley: They don't do one for a mkv, but the mkiv ones can be made to fit.
Offline mr magoo
« Reply #5 on: 31 December 2009, 19:05 »
Could it not be that the water's frozen? That happened to me last week (rear screen onlly...)
Offline jonboy90
« Reply #6 on: 01 January 2010, 11:55 »
thats what i originally thought but surely it uses the same water tank as the front washers? and their working fine.
Offline Hurdy
« Reply #7 on: 01 January 2010, 12:00 »
If it is still only dribbling then try a hairdryer on it to make sure it isn't partially frozen at the tip. The fronts tend to get the benefit of the engine heat once warmed up, but the rear doesn't :smiley:
Offline jonboy90
« Reply #8 on: 01 January 2010, 14:30 »
good tip i'll give it a go. cheers
Offline ub7rm
« Reply #9 on: 01 January 2010, 14:31 »
Also try fishing about with a pin in the nozzle in case its a piece of grit or something thats got lodged in it.
2020 BMW 128ti
2017 Golf GTD Estate
