Author Topic: Rear washer fault  (Read 1977 times)
Offline mb
Re: Rear washer fault
« Reply #10 on: 01 January 2010, 17:29 »
If you pull the black plastic cover off that covers the wiper spindle, you can remove the washer nozzle to give it a good clean.  You will need a pair of pliers to pull it off tho.
If you do remove the nozzle, remember to put it back on so that the water squirts to the 2 o'clock position and not straight up into the high level brake light.
