Author Topic: On my way to pickup the dreaded ecu Relay.... RESOLVED.. thanks for the help  (Read 2256 times)
Offline MrDan
When I find a lift down there.. no car is killing me!!
The beast is getting fuel and a spark but just not starting, Only codes on Vag-com are hall sensor that has been there for about 12 months (5k limit problem)
I cant take any more walking around in the cold!!! I hope this fixes it
« Last Edit: 22 December 2009, 21:37 by MrDan »
Re: On my way to pickup the dreaded ecu Relay..
« Reply #1 on: 18 December 2009, 11:18 »
Have you checked the cam timing reference 5k limit problem.
Offline Len
« Reply #2 on: 18 December 2009, 11:19 »
If your limited to 5000 revs then the ECU relay wont fix it!
Its a timing issue and probably that hall sender as well.
www.sas.org.uk
www.the-ace.org.uk
Offline MrDan
« Reply #3 on: 18 December 2009, 11:23 »
But it was working fine, just wouldnt rev past 5k,
does the belt slip a tooth?
« Reply #4 on: 18 December 2009, 11:41 »
It should not but if the tensioner was to come loose it could happen.
Reworded to suit Len
« Last Edit: 18 December 2009, 13:24 by Wayne »
Offline MrDan
« Reply #5 on: 18 December 2009, 11:41 »
just found this guys..
thanks Ill check tomorrow, might as well pick up the relay anyway
http://www.golfgtiforum.co.uk/index.php?topic=130997.0
Offline Len
« Reply #6 on: 18 December 2009, 13:00 »
It might do.
No it wont slip a tooth! If it did the tensioner would be loose and that would be disatrous!
It maybe one tooth out or as seen recently 180 degrees out! But that would be because the numpty that did it fitted the belt wrong!
www.sas.org.uk
www.the-ace.org.uk
« Reply #7 on: 18 December 2009, 13:27 »
It might do.
Just for info, I have seen cam belts jump a tooth.
Offline Len
« Reply #8 on: 18 December 2009, 15:23 »
 :rolleyes:   :lipsrsealed:
www.sas.org.uk
www.the-ace.org.uk
Offline MrDan
« Reply #9 on: 19 December 2009, 19:06 »
hi guys, thanks for you input on this.
changed the ECU relay anyway but no dice, due to being hungover and it being very cold im going to look at the timing tmorrow,
would my best bet to do the following,
- remove cambelt cover and move engine to TDC
then start with the dizzy? i think I understand the instructions...
