Author Topic: sub enclosures.....  (Read 2671 times)
kniterider
sub enclosures.....
« on: 11 October 2004, 14:55 »
right, as i need this to be removable i aint goin making any boxed in areas in the boot, so if any of you lot have a basic design for a sub box (10") could you post dimensions on here???
i have sh@t loads of mdf of different thicknesses at work so will make it there just need a 'plan' to work to!!!!
Gaz
Offline Len
Re: sub enclosures.....
« Reply #1 on: 11 October 2004, 15:19 »
If ya already got the speaker it will tell ya minimum volume - prob in cubic feet.
So to give yourself a bit of a front panel you will need a 12" x 12" to sit the speaker in. Then ya can make the depth of the box to suit the volume.
www.sas.org.uk
www.the-ace.org.uk
kniterider
« Reply #2 on: 11 October 2004, 15:40 »
ill have to check me sub (was in shelf) its somewhere safe so ill have to dig it out then and see what it says!!
Gaz ;D
Offline Len
« Reply #3 on: 11 October 2004, 15:56 »
Hope u've still got the box or the literature then.
If not try the manufactureres website, might give ya the info needed.
1 to 1.5 cu ft is usually enuff.
www.sas.org.uk
www.the-ace.org.uk
kniterider
« Reply #4 on: 12 October 2004, 07:20 »
right knocked up a box at work last night, dimentions are:
18"x14"x14" ive put a port hole in it as well as my sub hole (port hole can be blocked off again if not needed, so ill try it at the weekend!, i havent got a clue what the cubic whatever of that will be??? when its carpeted it should look sweet
Gaz 8)
Offline Len
« Reply #5 on: 12 October 2004, 11:29 »
Thats just over 2 cu ft. If those are external dimensions then it will be a bit smaller but will still be near to 2 cu ft.
So that should be a good size.
www.sas.org.uk
www.the-ace.org.uk
kniterider
« Reply #6 on: 12 October 2004, 11:38 »
yeah there external measurements, and the mdf is 3/4" thick, so hopefully will sound ok when done, gonna have to see how it sounds with the port open and closed before i carpet it......
Gaz ;D
