Author Topic: AUGUST orders list & thread.  (Read 221539 times)
Offline H12
Re: AUGUST orders list & thread.
« Reply #670 on: 18 March 2010, 20:10 »
Are you sure the light switch is in off 0?
Yes mate.. the neighbour across the road must be thinking I'm trying to land a jumbo jet with the amount of flashing lights coming from the drive evertime I have a go  :grin: :grin:
Offline H12
« Reply #671 on: 18 March 2010, 20:13 »
what do we reckon about running in period? 500 miles at less than 3000 revs?
I know there are various threads on running in periods on here.. I crept upto 4000 once but have been keeping it under 3000 generally myself so far..I intend to vary it more after 500 miles and then drive it with more welly after 1000
Offline Duncreflex
« Reply #672 on: 18 March 2010, 20:17 »
[/quote]
Sounds like a good plan  :smiley:
Gti mark 6, Candy white, 18" monza shadows, ACC, cruise control.
Offline H12
« Reply #673 on: 18 March 2010, 20:18 »
[/quote]
Sounds like you'll get there before me so let me know if the plan works  :grin:
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #674 on: 18 March 2010, 20:20 »
I know i had this wrote down somewere but cannot find it.  :embarassed: Theres a version to swtch them on too.
Try putting it so that the main beam is on rather than flash and see what that does. I think it may beep too, :undecided:
I wish i could find it.
EDITDRLs can be activated/deactivated by using the headlamp lever.
Ignition off. Lights to 'O'. Left turn on indicator (down) while pulling back (flash mainbeam), switch on ignition, hold for 4 seconds or so and you should here a beep. The DRLs are now off.
To reactivate is similar but you use Right turn on indicator (up) instead.
« Last Edit: 18 March 2010, 20:26 by Snoopy »
Current Garage:
35+ years of GTI ownership.
Offline Duncreflex
« Reply #675 on: 18 March 2010, 20:24 »
 :grin: will do.
Offline H12
« Reply #676 on: 18 March 2010, 20:25 »
I've tried both ways, Snoopy but am b&ggered if I can switch them off.. Must be me though because I haven't heard of anyone else who's had a problem. Well if you ever do find the intructions, that'd be most appreciated, mate
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #677 on: 18 March 2010, 20:28 »
No beep? Make sure the doors are closed too. I will look again its with other stuff i kept save (for when i would collect the car) like that Iplop lead part no etc. :embarassed: as i cannot find it  :grin:
« Last Edit: 18 March 2010, 20:30 by Snoopy »
Current Garage:
Offline H12
« Reply #678 on: 18 March 2010, 20:30 »
Tried that one as well but I'll give it another go over the weekend I think...  Thanks Snoopy
Offline p3asa
« Reply #679 on: 18 March 2010, 20:43 »
That process is for standard lamps.
Can the DRL's on the Xenons be turned off without VAG-COM?
