Author Topic: Boost Gauge Fitted - sorted! 27PSI anyone?  (Read 8109 times)
Offline Rhyso
Re: Boost Gauge Fitted
« Reply #30 on: 16 November 2009, 14:17 »
bah - nothing is fooking straightforward is it  :sad:
went to connect it all up at lunchtime; simples plugged in the t piece, connected it up and went for a spin; saw a MAX of 5PSI  :shocked: :undecided: Urm, no thats not right.......
So had a look around; couldn't see anything obvious - nothing trapped etc....so tried the t piece a different way and lo and behold it works! except it now buzzes again..........
After speaking with Mr Dave I believe I somehow need to connect one end back into the system much like you petrol lads do.....any suggestions?  :undecided:
Here is how its currently fitted:
It was originally fitted to the bottom piece but that doesn't show hardly any boost  :sad:
And here's how I modded the vent and what it looks like in the daytime
Offline Rhyso
« Reply #31 on: 16 November 2009, 14:27 »
That looks like a good job well done, i do prefer that over the steering column mounted ones as i imagine they get in the way of viewing the clocks.
Do you live near me i could let you do mine  :laugh:
only if you live anywhere near Merthyr in South Wales  :tongue:
how much effort is it to get it fitted in the vent?
looks awesome!!
took a bit of hacking as you can see from the pics but otherwise it was fairly straightforward  :smiley:
Offline Rhyso
Re: Boost Gauge Fitted - hopefully sorted!
« Reply #32 on: 16 November 2009, 15:02 »
right - looks like I was a bit of a numpty and fitted it the wrong way........
the T of the part goes to the boost gauge and NOT from the EGR delete  :embarassed:
I'll swap it around later and report back  :smiley:
Offline T_J_G
« Reply #33 on: 16 November 2009, 15:13 »
Should have put the slats of the vent back in!
Looks cool though Mr Rhyso
Offline Rhyso
« Reply #34 on: 16 November 2009, 15:22 »
I'll be looking into doing that at a later point  :smiley:  Though I still want some air to travel through the vent to help keep my window free of mist.
The slats also control a vent at the back similar to the one found on a standard air vent so in effect you get two block off points  :nerd:
I'll venture back out in a bit and fit the t piece correctly.........
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #35 on: 16 November 2009, 19:09 »
lol you plank
Offline Rhyso
« Reply #36 on: 16 November 2009, 19:55 »
lol you plank
I take it you got my last text then  :lipsrsealed:
What Wes is referring to is what was my actual problem at the very end.......
I did refit the t piece correctly before I set off home only to see zero boost  :sad:  Got home (went the gym) then got out my torch and had a poke around.  Turned out I'd kinked the pipe running into the back of the gauge  :embarassed:
Unkinked and took it for a quick spin  :evil:  Only a short piece of road but I saw 27PSI at approx 2200rpm, then 23PSI at approx 3500rpm before settling at 20PSI at the redline or thereabouts; that was done in 2nd and 3rd
So I finally have a working, non buzzing boost gauge  :grin: :grin:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #37 on: 16 November 2009, 20:08 »
yes I got your last text  :grin:
glad you got it sorted mate, thought it might be something simple as I was stumped  :nerd:
Offline Rhyso
« Reply #38 on: 16 November 2009, 20:11 »
wasn't sure as sometimes you don't get them  :lipsrsealed:
yeah for a change it was something simple  :smiley:
Offline northeast_gti-t
  • "1.8T AGU"
Re: Boost Gauge Fitted - sorted! 27PSI anyone?
« Reply #39 on: 16 November 2009, 20:43 »
nice one rhys :afro: told you that you'd sort it  :wink:
2000 Mkiv GTi 1.8T AGU
