Author Topic: Urgent help with TDI 130 PD, video of problem in post  (Read 15589 times)
Offline asif
 Right I was driving along not putting my foot down or anything and just generally picking up speed from second to third
next thing I know I hear a pop and loose power, I look in my rear view there is a fair bit of smoke not loads but more than enough to notice
the turbo wasn't kicking in after this so drove hoe really slowly using less revs as possible.
When I opened the hood I found this problem, a pipe come away, not sure what it is but can't get it back in.
Please see the video attached and can someone please tell me what's up and how much it will cost to get sorted.
Anyone else had this problem? Is it common?
http://s211.photobucket.com/albums/bb140/asifestoril/?action=view&current=CIMG3606.flv
« Last Edit: 18 October 2009, 17:56 by asif »
MK7 GT Bluemotion Tech TDi 150
Offline Steve_PD
Re: Urgent help with TDI 130 PD, video of problem in post
« Reply #1 on: 18 October 2009, 18:01 »
a intercooler hose a popped off :wink:
take the plastic cover off and your see the hose is not pushed in.
there is also a metal u shaped clip which holds the hose in place. see if you can find the metal clip.
the clip needs to be pushed around the metal EGR pipe first then the hose gets pushed in
heres a picture of a blown intercooler pipe on mine
you can see the metal clip
also check the lugs on the pipe for signs of wearing
Offline asif
« Reply #2 on: 18 October 2009, 18:37 »
 Cheers for the speedy response, I think the clip has dropped off as I can't find it.
I'll get the garage to put one on as it's going for a check on something else anyway.
Is this common???
Offline Steve_PD
« Reply #3 on: 18 October 2009, 18:39 »
yes its common :lipsrsealed: Ive got about 20 clips in my glove box :rolleyes:
Offline Rhyso
« Reply #4 on: 18 October 2009, 19:44 »
looking at the video is there any damage to the housing??
From a certain angle it looks as if you've had the same happen to you as it did to me in that you've shattered the EGR housing and you'll need a new one
That will be £190 by the way
Offline asif
« Reply #5 on: 18 October 2009, 23:15 »
Fook me what is the egr housing? is that what the pipe is connecting to?
What kinda damage am I looking for as it all seemed ok to me.
Offline asif
« Reply #6 on: 18 October 2009, 23:20 »
What causes this kind of thing happening?
Is it something i'm doing? Am I driving in a way that is making this happen?
Offline Rhyso
« Reply #7 on: 19 October 2009, 07:50 »
Yes - and you're looking for any pieces of metal that are missing basically
Yeah stop driving like an idiot  :tongue:
Not your fault mate - its the stupid clip design; under pressure the hoses move about and the lugs wear down until eventually there is nothing left to hold and your pipes blow off
Offline asif
« Reply #8 on: 19 October 2009, 08:33 »
Cheers for that Rhyso, right then i'm hoping this doesn't happen to often. Fingers crossed.
Offline Rhyso
« Reply #9 on: 19 October 2009, 08:47 »
sadly it will happen fairly often  :sad:
get all the pipework checked out and for the sake of a few quid replace ALL the clips  :smiley: and keep some spare in your glovebox  :wink:
« Last Edit: 19 October 2009, 08:50 by Rhyso »
