Author Topic: Urgent help with TDI 130 PD, video of problem in post  (Read 15597 times)
Offline Kerrse
Re: Urgent help with TDI 130 PD, video of problem in post
« Reply #10 on: 19 October 2009, 12:51 »
Cheers for that Rhyso, right then i'm hoping this doesn't happen to often. Fingers crossed.
sadly it will happen fairly often  :sad:
get all the pipework checked out and for the sake of a few quid replace ALL the clips  :smiley: and keep some spare in your glovebox  :wink:
Mine hasn't done it in a long time !! It has only happened once this year just after my remap so all good :) I would say never put the same clip back on once it has popped off always change it for a new one !! ( i also have about 10 in my glove box)
Offline asif
« Reply #11 on: 19 October 2009, 12:57 »
LOL so I take it I need to invest in some of these clips then.
Where do you guys buy them from? How much are they?
Also I hope this isn;t one of those daft questions that newbies keep asking but, how do you take the plastic cover off the engine to get to this hose?
MK7 GT Bluemotion Tech TDi 150
Offline Rhyso
« Reply #12 on: 19 October 2009, 13:04 »
Stealers is the only place
Just pull it off
Offline Steve_PD
« Reply #13 on: 19 October 2009, 17:49 »
and about 30p a clip :wink:
Offline asif
« Reply #14 on: 19 October 2009, 19:30 »
I took it to the garage and the guy there said I need to change the pipe as there is a metal bit that the clip clips onto and apparently that's broken off so the clip can't go back on properly.
He aslo said it's very common, the garage is a VAG specialist.
Offline Steve_PD
« Reply #15 on: 19 October 2009, 19:39 »
the lugs are worn, Ive replaced two of my pipes this year, lucky it never damaged your egr housing like Rhyso did
Offline Kerrse
« Reply #16 on: 20 October 2009, 12:25 »
I'd check it yourself lets face  it a garage would rather change a pipe than a 30p clip :)
Offline Adam
« Reply #17 on: 20 October 2009, 12:30 »
Buy a EGR Delete from allard and cut the cut off the original pipe.
Down Hill From Here.
Offline asif
« Reply #18 on: 20 October 2009, 12:34 »
What is all this about mate? I'm new to VW's and not mechanically minded so please explain, also what is the benefit of this mod?
Offline Adam
« Reply #19 on: 20 October 2009, 12:39 »
Its easy to fit, you could do it in less than half an hour.
Guide thanks to Rhyso for showing me it - http://www.bazmcc.com/faqs/EGRDelete.html
What you need - http://www.fuelefficientsystems.co.uk/index.php?page=egr-replacement-power-pipe-kits
