Author Topic: Golf Gti is getting LED back lights  (Read 164063 times)
Offline mac7
Re: Golf Gti is getting LED back lights
« Reply #310 on: 24 February 2010, 16:09 »
Looking good Mr FroG. I think I've seen that the foglight is LED, but is the reverse light too, or is it just an ordinary bulb?
Golf R
Offline SteveP
« Reply #311 on: 24 February 2010, 16:49 »
^^^ Normal bulb's in reverse and fog  :smiley:
Offline gizzywizzy
« Reply #312 on: 24 February 2010, 16:58 »
When are you gonna take the wraps off your car?
Gizzy
Offline SteveP
« Reply #313 on: 24 February 2010, 17:04 »
Now!  :grin:
Offline gizzywizzy
« Reply #314 on: 24 February 2010, 17:40 »
Now!  :grin:
Lol! Nice one looking good mate :wink:
Gizzy
Offline FroGTI
  • Wheel nut
« Reply #315 on: 27 February 2010, 07:31 »
Question to those who know about these things: do you think the normal indicator bulbs in these new lights can be changed to LEDs w/o having to go through the hassle of reprogramming again?
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #316 on: 27 February 2010, 09:25 »
It depends how its wired and what type of LEDs you get.
More than likely it will be one of two ways. a) Its wired the old fashioned way through a flasher relay. In which case it will flash the lights much quicker and think theres a bulb out. b)Its wired through the canbus system to each bulb and it will show a bulb out fault.
Current Garage:
35+ years of GTI ownership.
Offline mac7
« Reply #317 on: 27 February 2010, 12:10 »
Yes, it'll give a bulb out warning but I think the system maintains the correct flash rate.
However, I think you can buy LED bulbs now which have a load resistance built in to prevent the warning. Or, how about adding a load resistor to the relevant adapter cables (so you don't have to cut the OEM loom) - I've seen 25 ohm resistors on ebay for this purpose. A quick Google found this:
http://www.v-leds.com/BlinkerWarning-Fix/Warning-Light-Fix/LED-BULB-OUT-WARNING-p4481145.html
I imagine they'll get warm though, so you'd need to make sure other wiring is protected from them as a precaution.
Golf R
Offline SteveP
« Reply #318 on: 27 February 2010, 12:24 »
^^^^ shouldn't get too warm as the indicators are used too much. I had some LED's sidelights on my Mk5 for which I added in line load resistors which got warm but you could still touch them without it being too hot.  :smiley:
Offline Jimble
« Reply #319 on: 27 February 2010, 12:26 »
I think mr frog has an LED OCD!! :grin:
But seriously, looking really nice there sir!
