Author Topic: Golf Gti is getting LED back lights  (Read 164045 times)
Offline SteveP
Re: Golf Gti is getting LED back lights
« Reply #330 on: 27 February 2010, 18:16 »
Incidentally, I sprayed those weird orange indicator bulbs silver to get rid of the egg-yolk look. Yes, I know, I'm anal...
So you now have silver indicators rather than orange  :undecided:
I was talking about on the old, stock lights. And they flash orange as per normal, they just look silver when off so you can't see them through the lens. It's an old trick I've been using for years :wink: I might try the same thing with the new LED lights I fitted, but I'd really like to have an LED bulb in there first.
I have ordered some LED bulb's and load resistors to try so will let you know how I get on  :smiley:
Offline FroGTI
  • Wheel nut
« Reply #331 on: 27 February 2010, 18:25 »
Great, you have actually found some LED versions of VW's weird indicator bulbs? Can you post a link and/or pix? TIA :)
Offline SteveP
« Reply #332 on: 27 February 2010, 18:33 »
Yep the type is 7440 or WY21W for the indicators: -
http://www.autobulbsdirect.co.uk/ABD-7440-21W-9-LED-WEDGE-Red-or-Amber.html  :smiley:
Offline FroGTI
  • Wheel nut
« Reply #333 on: 28 February 2010, 07:47 »
Thanks, Steve. Did you get the resistors from the same place?
Offline SteveP
« Reply #334 on: 28 February 2010, 08:42 »
Nope already had some load resistors left from a previous project. eBay is awash with the 50w ali covered resistors  :smiley:
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #335 on: 28 February 2010, 10:10 »
The ones you are going to use i hope are reasonable rated as there will be a bit of power needed to be dissapated by the resistors as heat even at the ~50% duty cycle of indicators.
« Last Edit: 28 February 2010, 10:19 by Snoopy »
Current Garage:
35+ years of GTI ownership.
Offline FroGTI
  • Wheel nut
« Reply #336 on: 28 February 2010, 10:21 »
OK, so I have ordered 4 LED indicator bulbs like wot you said (thought I may as well do the fronts at the same time) :smiley:
I looked at eBay for the resistors: http://shop.ebay.co.uk/?_from=R40&_trksid=p3907.m38.l1313&_nkw=50w+resistors&_sacat=See-All-Categories, but there are dozens of them, all with slightly different references. Can you advise, please?
Also, I took a look at the rear LED blocks I just fitted to my car, but couldn't work out how to remove the indicator bulb holder. It doesn't seem to turn or pull out. How did you remove yours to get at the bulb? TIA :embarassed:
Offline SteveP
« Reply #337 on: 28 February 2010, 18:25 »
It just twisted out on mine   :undecided:
Offline FroGTI
  • Wheel nut
« Reply #338 on: 05 March 2010, 16:07 »
The LED indicator bulbs arrived today and, TBH, they're sh!te :angry: First of all, they only start flashing after about 10 seconds, until then they're just on all the time. This may be because I didn't install any kind of load resistor, though... Perhaps worse, though, is the fact that they're way too dim compared to the standard lights and, IMO, probably illegal. I removed the one I tried immediately and put the stock bulb back.
If anyone has any suggestions and/or remmedies, then I'm all ears.
Offline SteveP
« Reply #339 on: 05 March 2010, 21:01 »
^^^ How did you wire in the load resistors ???
I have mine to try at some point this weekend if I get a couple of rear view kits installs finished in time  :nerd:
