Author Topic: clutch pedal problem?????  (Read 2783 times)
Offline patty
« on: 06 October 2009, 15:37 »
hi,
my clutch pedal seems to only come back half way when the car has been parked for a while.
i pump it a couple of times,and it works again fine....could it just need bleeding?????
or is it someting more serious???
cheers
in advance
pat.
1996 black 5 dr 2.0 gti 16v
Re: clutch pedal problem?????
« Reply #1 on: 06 October 2009, 16:07 »
Is a 16v, if not then it is cable.
Offline hyland770
  • Vw Golf 1.6 estimated to have around 500+ bhp
« Reply #2 on: 06 October 2009, 16:57 »
bleed it and find out!?  :rolleyes:
« Reply #3 on: 06 October 2009, 17:22 »
If it is hydraulic, if not it could be a cable problem.
Offline patty
« Reply #4 on: 06 October 2009, 17:37 »
sorry guys its a 16v
pat
« Reply #5 on: 06 October 2009, 20:48 »
Sounds like a slave or master cylinder problem, bleed the system through and see if it helps.
Offline patty
« Reply #6 on: 17 October 2009, 20:32 »
now guys please be gentle with me,
has any one got any pics of where i bleed the system???? it's my first job in the morning.
as it caught me out a few times today,and i would like to get it sorrted asap.
got in the car first thing this morning and the pedal had already comprressed half way down.(does sound like a bleed is needed)
cheers in advance
pat.
« Reply #7 on: 18 October 2009, 10:14 »
Sounds like your slave cylinder has failed.
Offline patty
« Reply #8 on: 18 October 2009, 21:18 »
is there anyway of telling????? by looking at it??
are they expensive to replace???
cheers
pat.
Offline Paul86S2
« Reply #9 on: 18 October 2009, 22:55 »
Find the slave cylinder on top of the gearbox. Cylindrical object with a solid small diameter pipe going into it. There should be a bleed nipple at the end of the cylinder.
Bleed it as you would brakes and see if it makes a differance. Also check the system for leaks.
If its not this and to be honest it sounds more than a bleeding problem, you will probably find a seal has gone in either the slave or master cylinder, or you may have a leak in the system.
Paul
