Author Topic: clutch pedal problem?????  (Read 2758 times)
Offline patty
Re: clutch pedal problem?????
« Reply #20 on: 22 October 2009, 22:24 »
paul ,
 i will check the spring on sat, its worth a shot!!! (although i doubt it will be,nothings ever that easy for me..lol plus 99% it feels really good)
 i cant see bugger all outside at the mo,and im out all day 2morrow.
i have not disconnected the slave cylinder yet,if i did,what should i /should not see?????
cheers for all your help so far
pat.
1996 black 5 dr 2.0 gti 16v
Offline Paul86S2
« Reply #21 on: 22 October 2009, 22:36 »
No spring would be too easy.
Undo the two bolts holding the slave cylinder onto the gearbox casing. Withdraw the slave cylinder and there will be a push rod coming out of the end of the cylinder. If it is leaking you will see brake fluid coming out of the end. There may be a rubber dust cover or not cant remember you may need to look under this to look folr leaking fluid.
Paul
