Author Topic: Stodgy gearshift  (Read 4281 times)
Offline the boy mike
Stodgy gearshift
« on: 17 September 2004, 16:47 »
The gearstick operation on my Mk2 isn't as nice as it might be, but after 130k you can't really blame it. I've seen various bits claimed to improve this - some OE replacement parts and some aftermarket bits. I'll be investing in new shift bushes and ball pivot thingy; how much should I be looking to pay for these items?
I've also seen a Mk3 shift weight and various short throw kits. Where does the weight go, and has anyone used one? Are they any good? How about the short throw kits - any particular ones recommended?
As always, any advice is much appreciated.
Mike
Blue MK2
Re: Stodgy gearshift
« Reply #1 on: 17 September 2004, 16:51 »
this could also be another problem
http://www.oxfordshirevwoc.co.uk/gearstick_fix.htm
Offline Andy Mc
« Reply #2 on: 17 September 2004, 17:57 »
My gearstick felt very sloppy at about 100,000 miles, I had the linkage changed and it felt like new again. Not a big job to do either ;) I've heard that the weighted bar can transform the gear change, iliminating the clunky feel :)
'90 16v
Offline TIMMY
« Reply #3 on: 17 September 2004, 19:34 »
I had a similar problem but new linkages sorted it out and it really did feel
as good as new. Not expensive either.
Judderi
« Reply #4 on: 20 September 2004, 09:30 »
Golf nutz do the ball and cup and all linkages for about ?12.50
Offline Gambit
« Reply #5 on: 20 September 2004, 11:39 »
get the relay ball replacment from these guys, only ?6 and will come withing 2 days - this is where the most sloppyness is felt
http://www.4crawler.com/Diesel/ForSale/ShiftLinkage.shtml#A2RelayShaftBallCover
also a weighted shift rod, and shortshift set to about 30% will help loads
mk3 weighted shift rod is ?11 from VAG
« Last Edit: 20 September 2004, 13:10 by Gambit »
Offline Tucker
« Reply #6 on: 20 September 2004, 13:02 »
Hi people,
I done mine at the weekend, had a bit of trouble getting the pin out but made a big differance ;D (ball and cup)
Only one thing tho, to get 1st I have to push down on the gear stick as if I was going into reverse ::)
How can I get round this?? I even put on a new reverse stop plate but still no joy
Tucker
PS dont mean to nick the post but saves two on the go ;)
http://i10.photobucket.com/albums/a109/sydney04/mk116vsmallpic.jpg
Sig too large, see forum guidelines - Admin.
Offline Gambit
« Reply #7 on: 20 September 2004, 13:13 »
you just need to re-align yours
first off you need somebody to hold the gearstick in the neutral position if you dont have the special VAG tool for doing this
then, if you look in the engine bay where the actual rod comes out of the tunnel you will see a small clamp on the end of it. loosen it and turn it slightly towards the driverside of the car. tighten back up then go feel your gears. you just need to keep on playing with this till you get it where u want it
Offline Tucker
« Reply #8 on: 20 September 2004, 13:17 »
Humm...iv seen that when I have taken a box out of the MK1 but on this I can only see two bars with ball joints on. Is there still an ajuster on there then?
Tucker
Offline Tucker
« Reply #9 on: 21 September 2004, 22:56 »
Is there an ajust clamp on a MK2 ???
Tucker
