Golf mk2
Stodgy gearshift
Topic: Stodgy gearshift (Read 4282 times)
Gambit
Forum addict
Re: Stodgy gearshift
Reply #10 on:
22 September 2004, 09:09 »
hmm how to describe without a pic
this is for a mk2.....
the little ball on the relay shaft sits in a little cup on another rod - this translates the back n forth montion of the gearstick - at the end of this rod is the little clamp
on a mk1 you want to adjust the shift rod clamp as shown in this pic
http://www.4crawler.com/Diesel/ForSale/Images/shiftkit_11.gif
on a mk2 again its the shift rod clamp you adjust
http://www.4crawler.com/Diesel/ForSale/Images/shiftkit_31.jpg
Tucker
Here all the time
Reply #11 on:
22 September 2004, 09:15 »
Top job Gambit, will give her ago tonight, Does the car have to be in the air and me gets under or just open the bonnet?
Cheers my man
http://i10.photobucket.com/albums/a109/sydney04/mk116vsmallpic.jpg
Sig too large, see forum guidelines - Admin.
Gambit
Forum addict
Reply #12 on:
22 September 2004, 11:52 »
can be done with a good stretch with the bonnet open as long as the manifold aint hot.
although its easier to gain access from underneath
Tucker
Here all the time
Reply #13 on:
22 September 2004, 11:57 »
Tucker
Here all the time
Reply #14 on:
23 September 2004, 10:05 »
Iv seen the bugger, just need some time to sort her out now
Gambit
Forum addict
Reply #15 on:
23 September 2004, 10:56 »
easy enough job to sort, you just need somebody to hold the gear stick, or else rack up some device to hold it in neutral
VAG have a little tool which clamps on the little block on the side of the gearstick and holds it all in place. i.e makes it a one man job
Tucker
Here all the time
Reply #16 on:
23 September 2004, 11:04 »
I used my tool box on top of the stick to change the ball and cup
Tucker
Here all the time
Reply #17 on:
27 September 2004, 14:45 »
Job done, sweet as a nut
Gambit
Forum addict
Reply #18 on:
27 September 2004, 15:46 »
easy peasy
Tucker
Here all the time
Reply #19 on:
27 September 2004, 15:59 »
Sure was took me a few attemps tho, I was out and about last night and could not find reverse
so 1st thing today at 7.30 one more ajustment and she was all beautiful
Golf mk2
Stodgy gearshift
