Author Topic: Headunit..keeps resseting itself  (Read 2443 times)
Offline EuanGtTdi
« on: 14 September 2009, 22:09 »
Hi guys,
fitted my new cd player yesterday and when i start the car it all works fine and well i set it up etc etc but as soon as i turn the car off and take the key out the next time i put the key in a turn the power on, turn the cd player on and  go to listen to the cd player again all the settings have reset themselfs so have to set it up again like bass, treble, fade, what track were on etc!
my freind mentioned sniiping the red and yelolw cables of the cd player and swapping them over each other but duno if this is true?
any help please Euan
shrocco
Re: Headunit..keeps resseting itself
« Reply #1 on: 14 September 2009, 22:10 »
do this - end of story.
Offline EuanGtTdi
« Reply #2 on: 14 September 2009, 22:12 »
cheers mate do i just snip them and blank them off or do i re-join them so its red-yellow and red-yellow
shrocco
« Reply #3 on: 14 September 2009, 22:13 »
this.
Offline EuanGtTdi
« Reply #4 on: 14 September 2009, 22:23 »
Why is this? what causes this? have i bought the wrong headunit?  :undecided:
Offline S11EPS
  • No golfs here. Only a C63 mercedes
« Reply #5 on: 15 September 2009, 11:15 »
No.
What causes this is, whilst there is a standard for connecting headunits (ISO connector), manufacturers cannot agree which pin position should be the switched live and which should be the permanent live.
So, with some cars, it will all work perfectly out of the box. Other cars (VW's and Vauxhalls in particular) will need the perm and switched lives swapped around. You shouldn't need to cut the wires, as halfway along the loom the red and yellow wires should be naturally broken by means of a bullett connector.
You should just be able to pull these apart and join red to yellow and vice versa
The greatest leveller of them all - the Carousel
Offline EuanGtTdi
« Reply #6 on: 15 September 2009, 17:47 »
take it the bullet connectors will be behind the headunit in that pill of wires that connect to headunit mate?
thanks bud
shrocco
« Reply #7 on: 15 September 2009, 20:29 »
you could have done it ten times by now. it might have bullet connectors it might not. check it and see.
