Author Topic: glove box  (Read 1771 times)
Offline golfgar
  • Audi A6 estate/subaru wagon
glove box
« on: 29 August 2009, 22:33 »
Opened glovebox the other day and now its broke!!! looking pins stay in and handles hanging down ,like a spring or something has broke!! any ideals on how to fix? :angry:
Offline Steve_PD
Re: glove box
« Reply #1 on: 29 August 2009, 22:37 »
you either have to take the glove box out and try to split it to repair (its glued together)
buy a new one and fit that
or do what I done and cut a flap into the back of glove box, clip the catches back together and then put a metal plate across it to hold the flap back down. its not pretty but it works and saves £100 in buying a new one
Offline golfgar
Re: glove box
« Reply #2 on: 29 August 2009, 22:40 »
cheers mate,where do i cut? right behind catch?and how big a hole?
Offline Steve_PD
Re: glove box
« Reply #3 on: 29 August 2009, 22:42 »
you got the raised section on the rear, I cut three sides and scored the forth so I could fold it back
Offline golfgar
Re: glove box
« Reply #4 on: 29 August 2009, 22:47 »
cheers steve,will have to give that a go!  :grin:
Offline andybod
Re: glove box
« Reply #5 on: 30 August 2009, 09:51 »
not too bad a job to split the glove box just take your time and don.t use too much force when splitting  this is the way i did mine then repaired it then used a couple of small self tappers and washers to hold the levers in place and used some epoxy resin to glue the glove box back together all fine now
Offline Adam
Re: glove box
« Reply #6 on: 30 August 2009, 13:09 »
Mine did this the day I got it! Did what golfgar did to fix it.
Down Hill From Here.
Offline barry-gti
Re: glove box
« Reply #7 on: 30 August 2009, 16:36 »
The're £100??
Offline jtomlin
  • 1999 AGU 1.8T GTI
Re: glove box
« Reply #8 on: 30 August 2009, 20:18 »
i read this thread before i left the house, went to halfords to pick some sidelights up, opened the glovebox, and geuss what happened!  :cry:
Offline golfgar
Re: glove box
« Reply #9 on: 30 August 2009, 20:21 »
someone better lock this topic!! could be a jinx :grin:
