Author Topic: turbo priming...  (Read 1313 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
turbo priming...
« on: 23 August 2009, 21:59 »
What do you lot suggest for priming the turbo?
I've put some oil in the feed already but I was thinking of disconnecting the igntion amp and turning it over for a minute or so to make sure there's some oil going around?
Offline johnson6672
Re: turbo priming...
« Reply #1 on: 23 August 2009, 22:02 »
That sounds like a good way to do it, but will you get enough pressure from turning over, would have thought that if you have manually primed it you should be good.
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline topher
  • Administrator
  • fully functioning
« Reply #2 on: 23 August 2009, 22:22 »
loosen the top banjo and prime until oil comes out, then nip it back up tight and prime again for about 20 seconds.. should see you right
Offline J6BXR
« Reply #3 on: 23 August 2009, 22:32 »
Used to pack old ford oil pumps and turbo feeds with peroleum jelly before start up...... seemed to work.
cheers
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 23 August 2009, 22:33 »
I can't loosen it without getting the manifold off again lol
Offline topher
  • Administrator
  • fully functioning
« Reply #5 on: 23 August 2009, 22:36 »
You'll probably be okay just cranking over for about 30 seconds.. but the method i described is the recommended way. If you have something to block the return feed in the sump you could crank until oil p!sses out of the return line.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 23 August 2009, 22:45 »
I'll prob be ok to take the oil return off the sump and do it that way, I've got the gasket and new bolts. I'll see what I can find to plug the hole, might just end up being my thumb  :grin:
