Author Topic: Turbo internal cleaning - Reply needed ASAP!  (Read 1881 times)
Offline MK3TDi1996
« on: 02 August 2009, 16:09 »
hi folks,
just out cleaning my egr/intake manifold at present (man there was a lot of crap in there!) and i'm looking at my turbo intake and seeing all the gunk and s**t in there - can I pour anything down inside to clean it or any other methods? Or should i just leave it be...?
Thanks
Offline MK3TDi1996
Re: Turbo internal cleaning - Reply needed ASAP!
« Reply #1 on: 02 August 2009, 16:41 »
seriously.. anyone....
Offline topher
  • Administrator
  • fully functioning
« Reply #2 on: 02 August 2009, 16:42 »
just wipe out what you can reach.. don't go pouring stuff in it
Offline Mikester
  • Civic Type R
« Reply #3 on: 02 August 2009, 16:44 »
Carb Cleaner probably, and a cloth will do just fine, as topher says.
gtigolfthree
« Reply #4 on: 02 August 2009, 16:47 »
Ideally you want to remove it and clean it properly.
Offline MK3TDi1996
« Reply #5 on: 02 August 2009, 16:56 »
okay removing is no problem, what can i do to clean it once it's off?
Offline topher
  • Administrator
  • fully functioning
« Reply #6 on: 02 August 2009, 16:58 »
Carb cleaner, 'gunk' from halfords.. thinners, petrol.. whatever. Just make sure its clean and dry before you put it back on. That is assuming you're taking just the intake pipe off to clean, and not the whole turbo :afro:
Offline MK3TDi1996
« Reply #7 on: 02 August 2009, 17:01 »
oh no see i'd like to clean to whole turbo, if not possible, no worries, just need to know asap before i put the intake manifold back on
Offline MK3TDi1996
« Reply #8 on: 02 August 2009, 18:56 »
I'll take that as a 'no' then....
« Reply #9 on: 02 August 2009, 21:32 »
Use carb cleaner and a lint free cloth, just clean the gunk out.
