Author Topic: Turbo internal cleaning - Reply needed ASAP!  (Read 1883 times)
Offline boneybradley
  • Back in a Mk3...
Re: Turbo internal cleaning - Reply needed ASAP!
« Reply #10 on: 02 August 2009, 21:59 »
just be carefull messing with the turbo as you could easily ruin the oil seals and possibly the balance!
Offline DOA
« Reply #11 on: 04 August 2009, 18:13 »
You can clean it with pretty much anything that cleans and isnt likely to cause corrosion but make sure its pretty dry before fitting (dont worry too much, anything exhaust side will be promptly burned off and anything inlet side will get burned in the engine) and prime the oil system before you start it up if you go cleaning the centre section out (or pouring tons of cleaner in there). Whatever you do, dont try taking the wheels off for cleaning, they are balanced and you will put this out by seperating the assembly which you "might" get away with but "probably" wont.
Its not going to make much of a difference to the cars performance though  :tongue:.
Offline MK3TDi1996
« Reply #12 on: 04 August 2009, 20:47 »
Thank you sir!
What is this priming the oil of which you speak?
