Golf mk3
hardmonkeys
8v out of puff at 5000rpm....wtf ?
Topic: 8v out of puff at 5000rpm....wtf ? (Read 4517 times)
DAVEMARX
Here all the time
19 June 2009, 12:40 »
Didnt know mk3 8 valves were so sh!t....,
I got a 95 8v gti and its a load of pants i also got an 8v mk2 gti running a digi and it pisses all over the mk3.
The mk3 is out of steam at 5000rpm in all gears wth is wrong with these things i cant understand how an engine can be so pants.
i have to rev it until the valves pop out and jump allover the bonnet its shocking!!!!
should it be like this or is something wrong?
anyone else got the same problem?
dave
Wayne
Sir Postalot
Re: 8v out of puff at 5000rpm....wtf ?
19 June 2009, 12:45 »
Check your timing, if wrong it will go into safe mode.
snifferdog
19 June 2009, 12:49 »
as above,ive had this same problem on 2 different mk 3's!!although,they aint much quicker when fixed,haha.
DAVEMARX
Here all the time
19 June 2009, 12:53 »
safe mode ?
Wayne
Sir Postalot
19 June 2009, 12:55 »
Quote from: DAVEMARX on 19 June 2009, 12:53
safe mode ?
Yes limits the revs to 5k.
DAVEMARX
Here all the time
19 June 2009, 12:58 »
how do i get it out of safe mode is it just the timing?
snifferdog
Reply #6 on:
19 June 2009, 13:05 »
Think it is mate,mine went to the local vw both times.If i remember correctly,there was an issue with the maf sensor one time too?!
Khare
Serious forum addict
The bear that khares
Reply #7 on:
19 June 2009, 13:14 »
timing.
Wayne
Sir Postalot
Reply #8 on:
19 June 2009, 13:37 »
Quote from: DAVEMARX on 19 June 2009, 12:58
Check and reset the timing, then I believe leave the ecu disconnected for a short while and it should clear.
DAVEMARX
Here all the time
Reply #9 on:
19 June 2009, 14:17 »
Thanx guys Anyone got a linky to show how to reset it and once done what sort of rpm is it suppose to peak at?
cheers
dave
Golf mk3
hardmonkeys
