Author Topic: 8v out of puff at 5000rpm....wtf ?  (Read 4504 times)
Offline Khare
  • The bear that khares
Re: 8v out of puff at 5000rpm....wtf ?
« Reply #10 on: 19 June 2009, 14:19 »
when wayne says reset the timing he means reset it to factory spec...so back to were it should be.
My 8v hits the limiter at just over 6000rpm and peak power is at 5500rpm.
Offline DAVEMARX
« Reply #11 on: 19 June 2009, 14:24 »
I know what he meant thats pretty obvious. And obviously it needs to go to a garage but a link on how this is done would be handy..
Offline Khare
« Reply #12 on: 19 June 2009, 14:25 »
why do you need a link if a garage is going to do the work?  :huh:
Offline spunkymonkey
  • Tepidly moist! That's what that is!
« Reply #13 on: 19 June 2009, 17:39 »
This seems to be common when someone has done the cam belt and not timed it up correctly. The ignition timing isnt adjustable.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #14 on: 20 June 2009, 12:44 »
Yep, could mean that the cambelt has been fitted a tooth or two out of line of TDC.
Offline LostBok
« Reply #15 on: 20 June 2009, 17:10 »
2.0 8v should pull cleanly to about 5600rpm, but will have nothing over 5700rpm... rev limiter should be around 6600rpm, but no point in revving past 5800rpm (5500rpm on some cars!!) unless you have high lift cams  :evil:
LOSTBOK
Audi A4(B6): 2.5TDi Quattro Sport: Factory fitted Xenons, BOSE, and full sports leather "Soul Black / Titanium".
Mods: All OEM: S-Line bodykit, RNS-E, Bluetooth, Audi R8 FBMFSW, SDS-High voice control, full DIS, cruise control, Aero wiper mod.
In progress: 5 x OEM S4/Ronal 'Avus' 18's & 235/45ZR18 Toyo Proxes T1-R (bah! wheels delayed until WC 27-JUL-09)
Researching: Colour DIS, Freeview and DAB tuner with iPodvid/PSP/AV in for the RNS-E.
Offline avengedslayer
« Reply #16 on: 20 June 2009, 17:18 »
mine drops bang on 5k, i only had timing belt done a month ago! but i find it seriosly nippy and never rev it that high anyway so safe mode all the way for me :smiley:
« Reply #17 on: 20 June 2009, 17:22 »
I dont see why you would run a car that clearly isnt running right. Safe mode is a temporary mode.
« Reply #18 on: 20 June 2009, 17:24 »
dunno seems to run fine just doesnt go past 5k not that i push it that hard anyway! so safe mode is a temp status maybe it revs past 5k now?
« Reply #19 on: 20 June 2009, 17:27 »
No its temorary as in it will get you home or to the garage. You have a problem that needs sorting, if the garage did it then they should sort it.
Cambelts are not something to be taken lightly. If its a tooth out your risking the head, valves and many other things.
