Author Topic: Mk3 golf gti 16v , judders between 3 and 4000 revs  (Read 5731 times)
locin78
Hi , i have a 1997mk3 2.0 16v gti, it has a prob between 3000 and 4000 revs it lacks power and judders i have to drop a gear and get it by 4000 revs so it stop's it can do this in all gears , and when just standing it tick's over not so well either it sounds like it miss but its not as it did this befor i changed the plug's leads ect can anyone help thanks .
Offline Tuccy
Re: Mk3 golf gti 16v , judders between 3 and 4000 revs
« Reply #1 on: 01 June 2009, 09:06 »
Hi there,
My girlfriends car done this too, it was intermittent, but usually between the revs you mention, chucked it onto vag com and it indicated a faulty lamba sensor, when we changed it, it cured the prob.
maby your having the same issue..
good luck
Thomas
locin78
« Reply #2 on: 01 June 2009, 16:55 »
Hi Thomas thanks i will look into this someone else did say it may be the mass air sensor but i'll leave that till last as it will cost a packet lol
thanks Nic
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
« Reply #3 on: 01 June 2009, 21:57 »
Wont be the maf as 16v's dont have one, they have a map senser which is actually part of the ecu.
 I'd start by getting the car checked for any fault codes and as mentioned in other threads those relays can be a cause of these issues aswell and wont do any harm to change em.
locin78
« Reply #4 on: 02 June 2009, 20:08 »
i  have had it checked twice and no codes came up but they did recomend changing the lambda sensor so i will be this week end is see how it is after that then go from there...
« Reply #5 on: 03 June 2009, 08:27 »
quick test for lambda, simply unplug it! if problem is solved you need a new one. if you disconnect it it reverts to a base map.  other thing it could be is ecu temp sensor, they can fail but still return values within a range the ecu expects, so no fault is flagged.  its the 2 pin white one on side of head, always go vag for these :)
Offline nikkim53
« Reply #6 on: 04 June 2009, 14:53 »
I had the same problem with mine, got told all sorts of things it could have been (dizzy cap, fuel injectors, ecu/fuel relay) needless to say all got changed but still had the problem.
Have recently found out it was the air flow meter, changed that and the car has been running like a dream.
Try taking off the air flow meter plug and try to drive it !!
locin78
« Reply #7 on: 04 June 2009, 21:30 »
i just plugged my vag-com 409-1 into my car it came up with position sensor to short or to open to ground, what evar that means but would this cause the problem i have with the car??????
locin78
« Reply #8 on: 04 June 2009, 21:31 »
for got to say the fault code was G69
Offline Diamond Hell
  • Opinions я Us
« Reply #9 on: 04 June 2009, 23:50 »
So this problem has occurred since you changed the plug leads, yeah?
Swap 'em out for the old ones first, or a known-good set and then start pulling other things to pieces.
