Author Topic: Mk3 golf gti 16v , judders between 3 and 4000 revs  (Read 5732 times)
locin78
Re: Mk3 golf gti 16v , judders between 3 and 4000 revs
« Reply #20 on: 29 June 2009, 23:20 »
mine would judder between 2500 and 3000 revs anything after that it would run better it would do it in any gear when i plugged the vag com in it came up with possition sensor i check it and the wiring the wiring us f**ked so my mate double checked it at his garage and comfirmed it was causeing the fault so its getting sorted on thursday!
locin78
« Reply #21 on: 06 July 2009, 18:03 »
right i replaced the wires and throttle body and sensor's and it runs a lot better just need to reset ECU  , its stopped juddering between rev's there is only a slight hesitation at 3000 revs for a split sec then its all ok.
Offline Len
« Reply #22 on: 06 July 2009, 20:47 »
Change the ECU relay! :rolleyes:
www.sas.org.uk
www.the-ace.org.uk
locin78
« Reply #23 on: 08 July 2009, 22:23 »
it was my fuel relay thanks nic
Offline ramjet
« Reply #24 on: 26 July 2009, 15:53 »
Hey guys,
What number did the relay have on it.167 or 80?I am stomped with the same problem.Irritating jerking all the time.
Thank you for your assistance.
Ramjetvw
Offline boneybradley
  • Back in a Mk3...
locin78
« Reply #26 on: 26 July 2009, 20:34 »
i think it was 80 on it its on the top row 2nd one in from the left. just take it for a run then feel them if 80 or 167 are cold then replace them if warm to touch then they should be ok.
Nic
