Author Topic: Heater Controls - Should they light up?  (Read 2792 times)
Offline jezza16v
« on: 21 May 2009, 23:45 »
Hi, been out for a run tonight & noticed I couldn't see the heater controls at all.
Is that normal or is there a bulb or two blown behind them? (8v digi)
Offline nealey
Re: Heater Controls - Should they light up?
« Reply #1 on: 22 May 2009, 00:36 »
Yes they should illuminate, there is a bulb in there but its a sealed unit and is a nightmare to take apart without damaging it apparantly
Offline jezza16v
« Reply #2 on: 22 May 2009, 06:22 »
Thanks, I'll do a search & see what I can find...........
Offline Ben Lessani
« Reply #3 on: 22 May 2009, 08:45 »
The bulb you can get to easily - that removes with ease.
But stripping down the rest to fit LEDs instead just results in it snapping to bits! So be gentle.
Offline jezza16v
« Reply #4 on: 22 May 2009, 09:08 »
OK, how does the control fascia come off? I can see the levers just pull off, does the rest just unclip or do you have to get behind the dash to unscrew anything?
Offline Ben Lessani
« Reply #5 on: 22 May 2009, 09:11 »
Just pull the levers and knobs off - but I'm sure there is a couple of securing clips maybe a screw, but I can't remember
Offline tobz.
« Reply #6 on: 22 May 2009, 09:54 »
Once the control levers are off the fascia just unclips. Kind of push it down and try to twist the top out simultaneously and it will pop off. The bulb cannot be replaced without breaking the housing open. Your best bet is find a good un at the breakers or on ebay.
You got any pics of your dad's split ?
Offline jezza16v
« Reply #7 on: 22 May 2009, 10:29 »
Thanks all, I'll give it a go and see how I get on.   :smiley:
Offline Steve_B
« Reply #8 on: 22 May 2009, 12:17 »
I have a guide on how to replace the bulb from when I installed leds. Should be able to follow it to put in a bulb instead of an led. Let me know if you want it and i can mail it to you  :smiley:
Offline jezza16v
« Reply #9 on: 22 May 2009, 23:10 »
Thanks, I may take you up on that if I get stuck.
