Author Topic: Heater Controls - Should they light up?  (Read 2809 times)
Offline monzablue16v
Re: Heater Controls - Should they light up?
« Reply #10 on: 23 May 2009, 01:52 »
I have a guide on how to replace the bulb from when I installed leds. Should be able to follow it to put in a bulb instead of an led. Let me know if you want it and i can mail it to you  :smiley:
Put it up on here :) I'd like to have a look as well, tempted to LED it whilst the dash is in bits :)
Offline baronvontinkle
« Reply #11 on: 19 October 2009, 12:13 »
I know this is an old topic but it applies to what i need to know. The bulb that is in the heater controls, does anybody know what it is call because i have got into the housing and need a replacement (the old one i tried to get out smashed) also can you get them in red?
Thanks
Offline Ben Lessani
« Reply #12 on: 19 October 2009, 13:28 »
Its just a 12v 5mm LED. You can get them in any colour you want ...
http://www.maplin.co.uk/module.aspx?moduleno=35782
« Reply #13 on: 19 October 2009, 13:35 »
Cheers! Will go get myself a couple now
Offline Ben Lessani
« Reply #14 on: 19 October 2009, 13:38 »
Be careful removing it though, its not easy, the grey bit cracks very easily.
« Reply #15 on: 19 October 2009, 14:28 »
I've already removed it n it cracked abit but nothing some glue won't sort out. Got some LEDS. Gonna try em out now
Offline weazgti
« Reply #16 on: 19 October 2009, 20:09 »
Dont you need a resister? i got some leds from maplin for £3 last week to replace mine but when i tried my fascia out on a small battery they glowed once then blew.
Offline Ben Lessani
« Reply #17 on: 19 October 2009, 20:48 »
Not for a 12v led.
« Reply #18 on: 19 October 2009, 20:57 »
All I got was a 5mm 12v LED that cost about 46p n it works perfectly. Took abit of fitting cos of the seized parts but looks the part now
