Author Topic: PG TANTRUM 1200.1 MONOBLOCK  (Read 2822 times)
Offline AZIM
« on: 10 August 2004, 22:35 »
Ive recently brought this amp to power a Kicker 15" ls7 dual 4 ohm sub .
I need to know to get the best out of this amp do i need to buy the following ????
1   PG pro line driver
2    pg bass cube
Or will it be all right by it self to power the sub??
Its rated at 1400 watts rms ( so they say), to achieve this would i need to boost my charging system to obtain 14.4v ???
Please help me out , iwant to get it right first time!!
Anybody got one , is it all its made out to be!!!!
Offline Dizzie
  • Make friends with your fast
Re:PG TANTRUM 1200.1 MONOBLOCK
« Reply #1 on: 10 August 2004, 23:44 »
you'll probably need 0 gauge cabling to power that beast. I don't know much about the PG amps. If you haven't already put a bigger alternator on to keep the juice flowing. with that phat cable it should be alright.
Mk4 Golf 150PD
Offline lints
Re: PG TANTRUM 1200.1 MONOBLOCK
« Reply #2 on: 16 August 2004, 15:14 »
id say it'll be fine to power the sub without line drivers etc.., wire it to show 2ohm rather than 8ohm to drag as much juice from the amp as possible, as for 14.4v, that i think is what a car should be chucking out, engine at average driving revs, at tick over it's about 0.8v lower. and everything off is anything from 12v - 13.2v for a fully charged battery. make sure your earth is as thick as your power, and uprating the big 3 would also help alot wityh the power supply.
Don't know what the state of your battery is but if your getting dimming lights then i'd consider running an uprated battery upfront, or even a second battery in the boot (which i've done) then you should never have power issues unless you really go wild :)
Offline AZIM
« Reply #3 on: 16 August 2004, 19:10 »
Thank you for the advice .  Do you think  i could run a Denon dca 800 amp 6 channel  amp plus the PG 1200.1 off 1 large battery  & 120 amp alternator plus a large cap ???( i dont fancy a extra battery in the boot !!!
 Or is it necessary  i should split charge & run a cap as well , to get the best out of the amps.
Offline lints
« Reply #4 on: 16 August 2004, 22:02 »
i've never used a cap so couldn't comment on them, but i reckon with a decent battery and good cabling you'll be fine :) my alts only 90, uprated from 55! and that keeps both batteries always topped up coping with 4 average amps and a xover so id see how you go. try fitting the biggest battery you can in the space available and see how it copes, you might find you don't even need cap in the end.
