Author Topic: problems problems and more problems!!!  (Read 6465 times)
Offline navmk4gti
Re: problems problems and more problems!!!
« Reply #10 on: 17 May 2009, 12:34 »
im going to actually head over to garage now see if hes open and have a chat thanks for reply mate...
ill update when im bak :smiley:
Offline rheady
« Reply #11 on: 17 May 2009, 14:08 »
If its the water pump avoid driving it far or its goodbye engine.
Offline navmk4gti
« Reply #12 on: 17 May 2009, 14:50 »
right just went for a little cruise... gave the car a good push also... and the tempreture was stable at 90! just where it should be its not going up or down now! im completely confused now  :undecided:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #13 on: 17 May 2009, 14:53 »
could be the temperature sender, this tells the ECU how much choke to put on via water temp
Offline navmk4gti
« Reply #14 on: 17 May 2009, 14:58 »
hmm i dont know if i should wait to see if the tempreture rises again or just change it??  :sad:
the car runs absolutely fine no juddering or idle problems or nothing.
its just the like when the whole engine shaked.. happened once then vanished  :undecided:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #15 on: 17 May 2009, 15:08 »
do you have VAG COM to check if the temp sender has an intermittant fault?
If not I'd change it for piece of mind anyways, it's not an expensive part
Offline navmk4gti
« Reply #16 on: 17 May 2009, 15:18 »
nope got no vag com.. if i get one of ebay will that pick it up if there is a fault?
Offline Voodoo-Music
« Reply #17 on: 17 May 2009, 16:04 »
really sounds like the water pump, dont be deceaved as i was.
My car did the same but just got worse, started getting a little hot then dropping back to 90 then it was fine for days then it just gave up all together
Sorry for the bad news if its the pump but it should only cost around £140 to have it changed dependant on whenthe last time you had the  belts done
Offline navmk4gti
« Reply #18 on: 17 May 2009, 20:33 »
you scared me now voodoo  :cry:
im pretty broke for another two weeks so ill have to see how goes until then .. im gonna drive it tomorow and tuesday for my exams then gonna just park it up until i got the cash  :sad:
why me  :cry: lol
Offline Ant1981
  • Feed me, prod me
« Reply #19 on: 17 May 2009, 20:36 »
If it continues to run hot, you'll end up with a head gasket failure.
'09 Kawasaki Ninja ZX-6R
