Author Topic: problems problems and more problems!!!  (Read 6440 times)
Offline navmk4gti
Re: problems problems and more problems!!!
« Reply #50 on: 20 May 2009, 20:29 »
can you check your average miles per gallon on ur mk4???... mine was readin 25mpg drivin like a granny!!!!!!! after i changed its back to the 34-36 mark  :smiley:
Offline Ant1981
  • Feed me, prod me
« Reply #51 on: 20 May 2009, 20:39 »
Well I took it for a drive and it's still over heating when the revs go up.
So, mine isn't the temp sender.
Basically, this could be the pump as circulation is obviously rubbish, as when I stopped and opened the bonnet, all was hot apart from the bottom hose, as the engine returned to 90 degrees under idle engine speed, the bottom hose become hot. This I wouldn't necessarily put down to a stat, but who knows, That's all there is, mechanical wise is pump and stat and electrical wise istemp senders.
 :undecided:
'09 Kawasaki Ninja ZX-6R
Offline navmk4gti
« Reply #52 on: 20 May 2009, 21:02 »
hmmm only other thing thermostat!  :undecided:
you taken it to a garage to have good check on it??
Offline Ant1981
  • Feed me, prod me
« Reply #53 on: 20 May 2009, 21:06 »
Garage can't see it til 3rd June  :rolleyes:
Failing that I could try a dude where I work, but it's getting it there, I'll have to drive, rest, drive rest.
I'll probably get one of them to do the pump, it doesn't seem like a thermostat issue as once the radiator bottom hose is hot, it'll stay hot, as the car just needs a chance to circulate it there. I've no doubt, considering my symptoms and other peoples past issues, that it is the pump.
Offline T_J_G
« Reply #54 on: 20 May 2009, 21:16 »
Can you see the water being pumped back into the coolant tank when you rev it?
Offline navmk4gti
« Reply #55 on: 20 May 2009, 21:17 »
yh if thats your symtoms then the pumps had a sissy fit  :sad:
makesure to replace it with a metal fin one tho! as iv heard VW decided plastic fins would be a good idea on a water pump which is mostly why they end up dying  :angry:
Offline Ant1981
  • Feed me, prod me
« Reply #56 on: 20 May 2009, 21:18 »
It's only an expansion tank isn't it?
Besides, non cable throttle, so would have to get an assistant.
Offline T_J_G
« Reply #57 on: 20 May 2009, 21:23 »
The water should  enter via the top hose still.
Offline Ant1981
  • Feed me, prod me
« Reply #58 on: 20 May 2009, 21:47 »
Well it probably does, at idle speed.
What I could do is try to see when it's first started, depends where this enters from, top of the radiator usually. I'll see, definatley pump if at idle it moves water and doesn't only when speed is increased.
Offline Ant1981
  • Feed me, prod me
« Reply #59 on: 21 May 2009, 18:10 »
I've ordered my new pump from Awesome GTi, £40 all in with delivery.
